Old 10-06-2011, 11:24 AM   #1 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Question Do engine mods change BSFC mapping?
Given the interest in mods of the engine as well as mods of the nut behind the wheel, I wonder...
Is it possible that I have changed the location of the "sweet spot" island on my car's BSFC map by modifying the engine with a WAI, an ignition timing advance by 2*, and removing PS, AC belts, and most alternator electrical load? The car on balance probably has more hp at the wheels now, no? In theory, should that change my BSFC mapping any? I would think it would. What do you think?
If I have changed the BSFC map then I need to readjust the nut behind the wheel... I should expect peak efficiency at load in different parts of the RPM arc than with the stock engine, no? What am I failing to understand that counts?
Old 10-06-2011, 11:28 AM   #2 (permalink)
Yes, engine mods will change BSFC mapping. To what extent we could only guess as we have no convenient way of measuring BSFC.
Old 10-06-2011, 02:37 PM   #3 (permalink)
And chances are pretty decent that you haven't moved the sweet spot very far.
-soD
Old 10-06-2011, 03:58 PM   #4 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
The changes to the accessories won't change the map at all. The same amount of fuel creates the same amount of power at the flywheel (where BSFC is defined). Because of the reduced accessory loads, however, a greater percentage of the flywheel power will get to the wheels--so to get the same power to the wheel you will be at a slightly lower fueling point on your map but the map itself hasn't changed at all.
Your timing advance will change your BSFC map, because the same amount of fuel will now generate more power. That being said, the shape of the map will probably stay virtually the same--the whole thing will just shift to a slightly lower BSFC.
All that being said, IMO these changes are far too small for you to try to change your driving style.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
The Following 3 Users Say Thank You to Diesel_Dave For This Useful Post:
California98Civic (10-06-2011), Cd (10-06-2011), slowmover (10-11-2011)
