View Poll Results: All else being equal, does fuel brand affect FE?
Yes, significantly
17 |
21.79% |
Yes, but not by a significant amount
27 |
34.62% |
No, there's no significant impact
34 |
43.59% |
11-18-2012, 08:25 PM
#41 (permalink)
...beats walking...
Originally Posted by ProDigit
Most cars nowadays have an MPG counter on their dashboard that's pretty accurate!
...if being consistently 5-10% too optimistic(*) is accurate, maybe...otherwise, give me a 'calibrated' SGII or UG.
(*) = what our GM Cruze MPG Display Information Center (DIC) reports.
11-18-2012, 09:52 PM
#42 (permalink)
Intermediate EcoDriver
My Mustang's information display is usually only between 3% and 5% optimistic, depending on seasonal fuel blend.
Largest difference was last Summer when the information display showed average MPG at 34.0 MPG. Actual was only 32.318 MPG.
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
11-18-2012, 11:00 PM
#43 (permalink)
Probably covered elsewhere but briefly tell me how the scan gauge can be magnitudes more accurate using the same data the car display does - or at least as I understand for my car - that is if the car is left with stock tires and everything else in stock norms.
I could understand how some car displays would be geared optimistic or some car displays limited in capability.
11-19-2012, 08:37 PM
#44 (permalink)
...beats walking...
SGII has user-adjustable "calibrations" for both (A) distance (MILES) and (B) fuel consumed (%)...OEM has neither.
11-20-2012, 01:21 PM
#45 (permalink)
I over heard the women I work with talking about how they need to buy gas more often than they use to. One women said shes seen a new sticker on the pump that use to not be there. Something about 10% ethanol. Another women was saying her car laguhs at her as it knows she will need to refill it up before the end of a week where a tank use to last a week and a half.
11-20-2012, 03:30 PM
#46 (permalink)
So 10% ethanol is reducing FE by over 33% (1.5 weeks/tank down to under 1 tank/week)? I suspect not. E10 only has ~3% lower energy content.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
11-20-2012, 06:24 PM
#47 (permalink)
Top Tier Gas
I found this article on Wikipedia interesting on differences in gas brands. It may not be a difference in the octane or energy rating directly, but the cleaner injectors being able to atomize it better.
Top Tier Detergent Gasoline - Wikipedia, the free encyclopedia
"While General Motors' fuels engineer Andrew Buczynsky says that no one has identified the exact molecule in gasoline that causes engine buildup, he says that top tier detergent gasoline will remove the deposits.[15] Engine "gunk" typically builds up in fuel injectors, intake valves, and in time may foul combustion cylinders. Without some level of detergents, engine deposits form in most vehicles and this causes reduced fuel efficiency, acceleration, and power, as well as increasing emissions, rough idling, and increased motor repairs.[16]"
11-20-2012, 08:27 PM
#48 (permalink)
My issue is the only non-ethanol gas around is 87octane and not a top tier station
When you get the higher octane blends at the pump, they mix in the higher octane gas and that has ethanol at this station. Haven't noticed a big difference either way, and it would take lots of A/B to determine....
11-21-2012, 08:34 AM
#49 (permalink)
EcoModding Alien Observer
My SG seems to be ~1.5 mpg too optimistic...around 4%. This is with everything "correctly" entered. Probably need to lower the engine displacement from 2.0L to 1.9L or so?
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
11-21-2012, 10:09 AM
#50 (permalink)
Beats me, one women drives a camry and she says its like 100 bucks to fill it up. Maybe shes using tier 3 preminum fuel?
