Old 12-08-2010, 07:56 PM   #1 (permalink)
Does 1990 Miata (manual) have DFCO?
Just curious if my 1990 Miata (manual trans) has DFCO and at what RPM it would engage. I'm testing EOC and like it (except that the check valve is missing to my brake booster which makes braking a little too exciting for the moment).
Old 12-09-2010, 02:45 AM   #2 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
Drive along at 3000rpm in 3rd gear. Take your foot off the gas and you will slow down. If the deceleration stops or significantly slows down at some RPM (around 1300rpm +- 500) you will have found the point at which DFCO is disengaging.
If you have Fuel injection it is likely you have DFCO.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 12-09-2010, 11:32 AM   #3 (permalink)
EcoModding Enthusiast
Silver Bullet - '03 Mazda Protege LX
90 day: 29.51 mpg (US)
90 day: 37.06 mpg (US)
Blaze - '17 Ford Escape
or you could try 1st gear if you're not sure, then you'll REALLy know, lol! Just don't try to do it whilst drinking a hot beverage...
Old 12-09-2010, 01:44 PM   #4 (permalink)
Thanks. I tried noth methods but there was no perceptible change inthe deceleration rate ineither instance. Guess i don't have it.
Appreciate the responses!
Newb w/ a Miata AntiochOG Introductions 33 05-26-2016 11:06 PM
Please explain DFCO (Deceleration Fuel Cut Off) trikkonceptz EcoModding Central 47 12-12-2010 04:34 AM
ScanGauge II does not show open loop under DFCO? Pappnese Instrumentation 6 09-06-2010 04:47 AM
Manual DFCO, EGR, accessory belt "clutches" usergone EcoModding Central 11 05-24-2010 10:14 PM
Manual, Auto and Semi-Auto Arragonis General Efficiency Discussion 7 02-07-2010 02:30 PM
