Old 05-24-2009, 01:40 PM   #1 (permalink)
Matt Herring's Avatar
Bone's 2010 Prius - '10 Toyota Prius Black
90 day: 56.78 mpg (US)
2010 Prius with Sunroof open...aero?
What do you think of the sun roof wind deflector on the new 2010 Gen 3 Prius? Pretty steep angle on the wind deflector on the front of the sun roof...seems odd looking to me. Any comments on it?
Old 05-24-2009, 02:19 PM   #2 (permalink)
Life isn't just about aerodynamics. Sometimes you want the sun shining down on the top of your head
Old 05-24-2009, 02:25 PM   #3 (permalink)
I thought the only reason I'm alive was to get max mpg...hmmm?
Old 05-24-2009, 09:14 PM   #4 (permalink)
Tartaruga - '09 Fiat Palio
Last 3: 23.7 mpg (US)
you can see in the picture, only used while stopped.
Old 05-24-2009, 10:09 PM   #5 (permalink)
What's only used when stopped...the wind deflector? How's that work?
Old 05-25-2009, 03:14 AM   #6 (permalink)
It certainly wont lower the drag
I wouldnt mind betting they had to go steep to stop the airflow diving in behind due to the good flow over the front.
Old 05-25-2009, 06:34 AM   #7 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
the opel calibra had a similar sunroof, the problem with sunroofs is that they take up headroom, especially when you want a roofline that starts slopeing down behind the driver, but still allows for rear passenger headroom (also like the calibra coupe wich was a full 4 seater not a 2+2) so you can eigher raise the roof and increase drag all the time even on vehicles without the sunroof (wich i assume is not standard as on most cars) . or you have the sunroof opening externally wich increases drag when open, but allows for a much lower roofline when closed... since its probably more comfortable anyway to run the airco and close the roof at highway speeds, the overall impact on aero of this setup will be far less than a permanent raised roof on all models. so if you want an opening sunroof, considdering aero this is the best option.
Old 05-25-2009, 10:02 AM   #8 (permalink)
It definitely will hurt aero. Use it tootin around town at 25 mph if you want to. Once you get up to any semi-fast speed, I'd close it up for sure.
Old 05-25-2009, 06:41 PM   #9 (permalink)
just kiddin'!
but always drive with it closed, we don't want to hurt our dear mpg's
Old 06-06-2009, 08:39 PM   #10 (permalink)
90 day: 51.82 mpg (US)
Yeah, that style of sunroof is an aero disaster. Flow separation at the highest point of the roof! Mr Kamm, your back is wasted here with that open.
But a sunroof is nice. My dad won't actually buy a car that doesn't have one.
Prius aero mods (undertrays, grille block, mirror delete...) krousdb Hybrids 46 08-02-2015 02:39 AM
Aero prius bodykit JMags Aerodynamics 30 10-22-2014 01:00 AM
PBS takes the Hummer v Prius bait SVOboy Hybrids 51 05-19-2010 12:35 PM
2010 Prius unveiled: Cd 0.25, 50 mpg EPA combined, EV mode MetroMPG Hybrids 56 07-26-2009 03:48 PM
Kit for aero modding Prius Cd Aerodynamics 10 03-17-2008 05:59 PM
