Old 01-10-2010, 02:17 PM   #11 (permalink)
90 day: 51.82 mpg (US)
Effect of a traditional pickup camper shell topper on drag / mileage
To add to the discussion:
1) http://ecomodder.com/forum/showthrea...p-off-601.html
Relatively well done on-road testing shows that specific cap increased drag.
2) http://ecomodder.com/forum/showthrea...ruck-1228.html
Obviously "traditional" cap styles vary a lot. Some increase frontal area, and have insufficient radii on the leading edges. Others are truck-specific and are nicely integrated into the OEM shape at the back of the cab.
ECONORAM (12-29-2012)
Old 01-10-2010, 02:57 PM   #12 (permalink)
Here's the Pop Mech Google Books link:
Popular Mechanics - Google Books
Their testing methodology is questionable. It's just "A-B-C", and doesn't say anything about how much effort they made to be as-controlled-as-possible.
I'm skeptical, and suspect they may be wrong.
Old 01-10-2010, 02:58 PM   #13 (permalink)
Wait a minute... So lowering the tailgate does reduce drag, presumably by creating a lengthened surface for flow to reattach to.
Old 01-10-2010, 03:07 PM   #14 (permalink)
One cap vendor posts this on their web site:
Documented tests confirm that the aerodynamic enhancements gained over open-bed pickups reduce the vehicle’s coefficient of drag and boost gas mileage.
source: Snugtop - Custom Fiberglass Manufacturing, Truck Cap & Tonneau Top Covers, Camper Shells Tops, Customized Truck Toppers, Pick Up Truck Canopy
... and of course provides no additional information about the tests. (Wonder if they're referring to the Pop Mech article....)
Old 01-10-2010, 03:08 PM   #15 (permalink)
Let's keep the discussion about caps please.
Old 01-10-2010, 03:20 PM   #16 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
I learned something odd with this subject and a lower compression 1979 chevy pickup. the engine got bigger to weight, and it reminded me of a 1960s gas 5ton truck...also with strangely factory low compression.
if you have high compression, performance engine, it is a tinny versus a sledge hammer. the tinny smackers, need to play aero games, the workers do not. the cap can do two different things on the same truck, depending on drivetrain. My own experience with the older low compression was sqaure cap, lack of aerodynamics, just to keep the engine chugging a bit more..INTO efficient.. Most noticable starting with the larger v8s (5.7 liter and onward) the smaller the engine, the more it is straining through any weight, any compression, making it less noticable.
It is almost like a tractor trailer- they are the same loaded sqaure, unloaded, winged looking like a ricer...it is all the engine, the engine, the engine....
the more I see wings and aero, the more I know the engine sucks.
Old 01-10-2010, 03:51 PM   #17 (permalink)
This (dead) link is supposedly to an SAE study using a pre-2004 model F-150:
Technology Enhanced Learning with Moodle
Which showed that a tonneau was the most efficient of all options studied, including traditional cap. (Not very useful unless we know details of the cap though.)
Old 01-10-2010, 04:20 PM   #18 (permalink)
Yes, the PM article's testing leaves something to be desired. Back in '82 they knew more than I did.
The Dodge article was done by students who did water tank testing on an itsy bitsy scale model that lacked who knows how much detail. I'd be loathe to read too much into the "values" given. I think they had no business going to that many decimal points.
The caps thing is fraught with variables as Metro noted; caps come in zillions of designs, many of them not fitting to the cab very well.
A quick Google shows many truck cap makers and retailers claiming better aero. Not much in the way of legit proof, except for the tonneau cover claim at the Leer site, which isn't germane to this.
Old 01-10-2010, 04:33 PM   #19 (permalink)
Bottom line is I don't think we've yet found quality evidence that shows a traditional cap outperforming some other traditional configuration (open bed, tonneau).
I wrote to the Snugtop people asking for more info about the studies they reference. I doubt they'll reply, but I'm willing to be proven wrong in my skepticism.
Old 01-10-2010, 04:47 PM   #20 (permalink)
The Truck - '06 Chevrolet Silverado Ext Cab 4x4
The PM article also uses a long-bed Isuzu which has a relatively short cab height and a very long bed.
With all the talk of rotating bubbles helping the air get to the tailgate - I'm sure the height of the cab and the length and height of the bed play a role. On a full-size short-bed truck, topper vs. tonneau vs. aerocap might be totally different than a small, long-bed truck.
PS - I used to own a 1984 Isuzu diesel 2wd longbed (with a square camper top) and consistently got better than 35 MPG. Unfortunately I never did any ABA testing with the topper. I wish someone made a truck today that would get that mileage.
CdA list Daox Aerodynamics 206 10-25-2023 06:32 PM
Article: pickup mileage - manufacturers are ecomodding their trucks for better MPG MetroMPG EcoModding Central 14 10-07-2009 11:49 PM
