Old 06-28-2019, 05:10 PM   #51 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
... I think the ideal thing would be to extend the moving belt out ahead of the car.
That's true. I wonder why they don't do that? Probably expense, I would bet. Maybe they can use the tunnel for more versatile types of testing if the Belt doesn't extend over the entire floor?
The Following 2 Users Say Thank You to California98Civic For This Useful Post:
aerohead (06-29-2019), TexasCotton (09-18-2019)
Old 06-29-2019, 10:02 PM   #52 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Right, and vacuuming it off has the effect of lowering the air pressure under the front of the car. Combining the vacuum slot and the moving belt, this could artificially give downforce on the front of the car.
I was just thinking about this more--over the stationary floor, the velocity at the floor/boundary layer interface is 0, so all the kinetic energy of the airstream there is being converted to pressure. That could make the pressure under the front of the car overly positive if not corrected, and suctioning it off could address that.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following 2 Users Say Thank You to Vman455 For This Useful Post:
aerohead (07-03-2019), TexasCotton (09-18-2019)
Old 07-03-2019, 11:10 AM   #53 (permalink)
stationary floor
The air immediately adjacent to the floor boundary is always at zero velocity,whether in a calm,or moving air mass.The difference would be whether or not a boundary layer was present,either laminar,or turbulent.For the size of a full-scale model,it would always be a turbulent boundary layer.
With a stationary-floor tunnel,without suction,you'd not only have a turbulent boundary layer forming and growing on the underside of the model,you'd also have one present and growing under the model on the floor.This creates 'Wall-Effect',choking off the inviscid free flow,accelerating it to an artificial high velocity and lower static pressure.This wouldn't happen in the real world.It is for this reason that you'd want to vacuum that layer away.Or provide a curved wall/ceiling to compensate for the blockage effects of the model in the test section.DARKO and A2 use this.
Old 09-18-2019, 12:12 AM   #54 (permalink)
TexasThunder Avg MPG 54 - '08 Toyota Prius Base
Thanks for thread
Old 06-15-2022, 09:47 AM   #55 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
I am doing CFD simulations with the a2 3L basic body shape. Seems like 230mm diffusor extensions at the same angle is good for -0,013 drop in drag coefficient.
280mm long was good for -0,015
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following User Says Thank You to Vekke For This Useful Post:
aerohead (06-16-2022)
Old 07-08-2022, 08:39 AM   #56 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Here comes few pictures on the topic
Best angle of attach was 0 degrees in cfd
3d printed air curtains in place in 3d model which is then rendered to look like car.
New rear spoiler
Rear fenderskirts+ rear air curtain.
, front tire deflectors, wheelcovers,front air curtains
More to come the diffusor and few other tweaks. The smooth covers are too dull looking so will put aluwheels with blocking plates to the model also.
The Following 2 Users Say Thank You to Vekke For This Useful Post:
aerohead (07-11-2022), freebeard (07-08-2022)
Old 07-08-2022, 10:25 PM   #57 (permalink)
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
wonder if those side skirts are hurting or helping the aero. they stick out a bit
Old 07-09-2022, 05:45 PM   #58 (permalink)
Protruding fenders usually indicate an effort to cover tires that are sticking out, which will prevent related traffic tickets. If so, the effect on fuel economy is probably a wash.
Old 07-10-2022, 11:20 AM   #59 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Side skirts hurt, that are those narrow shapes at door lower edge. To protect the door from bumbs etc. They come out about 30mm which is too much. Will take them out.
Rear fenders come out about 40mm so thats why I think that rear air curtain will work. Shape still needs tweaking
Old 07-10-2022, 12:10 PM   #60 (permalink)
Phase's Avatar
The Prius and a few other cars use small side skirts I’ve noticed. Surprisingly the Ioniq doesn’t use any. I was thinking of adding some small side skirts to help guide the lower air over my custom rear fender/wheel spats/skirts.
audi a2, drag, reduction, study, wind tunnel
