Old 10-01-2010, 04:05 PM   #21 (permalink)
I have to start over?
Big inefficient truck - '94 Dodge Ram 2500
90 day: 12.1 mpg (US)
Honda Civic - '84 Honda Civic DX Hatchback
What part number specifically did you use? Did it already have the spring in it, or did you buy that separately? I am seriously considering implementing this in my truck.
Old 10-02-2010, 01:02 AM   #22 (permalink)
There is no spring... ? The cylinder dimensions will depend on the accelerator pedal dimensions as well as the distance from the cylinder attachment to the fulcrum point on the pedal. I would buy a stainless cylinder, and the vacuum reservoir isn't necessary as long as the seals don't leak in the cylinder.
It shouldn't be difficult to assemble a lean/stoich/rich indicator for your typical narrowband O2, and there are a number of them on the market as well, IMO far more useful than a vacuum gauge.
Old 10-02-2010, 08:13 AM   #23 (permalink)
Ok, gotcha. Thanks
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Aftermarket Cruise Control, AKA Hand Throttle. Hugh Jim Bissel DIY / How-to 19 08-04-2009 12:49 AM
Throttle sensitivity Formula413 EcoModding Central 13 05-29-2008 04:55 PM
