Old 11-23-2020, 10:33 PM   #11 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Here's the Leaf's diffuser:
It has a pronounced upward curve. I measured the diffuser panel on my Prius at 10 degrees from horizontal.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
aerohead (11-25-2020)
Old 11-23-2020, 10:57 PM   #12 (permalink)
^^ That's a nice part. I'll bet wrecking yards have a supply of them.
Old 11-23-2020, 11:51 PM   #13 (permalink)
Yes, I used 10 degrees on my Insight, the figure based on the SAE paper research I did when writing my book.
Note that this figure is dramatically different from the 'rule of thumb' that has been disseminated here over many years.
Old 11-24-2020, 03:27 AM   #14 (permalink)
IRONICK's Avatar
The degree of the diffuser also depends on the angle of the car's roof when combining flows.
But obviously it has to be like you in the book.
The Following User Says Thank You to IRONICK For This Useful Post:
Old 11-24-2020, 08:36 AM   #15 (permalink)
Moderator
Vman455's Avatar
Yes, you're exactly right--the optimum diffuser angle will depend on the shape of the particular car in question, which is why you should test it. The "2 degree diffuser angle is always best" rule has been bandied about here for a long time, but that clearly isn't the case given that low-drag production cars sometimes use much steeper angles!
And now you've devolved into (unfounded) personal jabs.
Old 11-24-2020, 05:21 PM   #16 (permalink)
IRONICK's Avatar
I'm already testing it, but not on the electrical model.
Old 11-24-2020, 05:22 PM   #17 (permalink)
IRONICK's Avatar
Maybe a little respect for colleagues on the forum and less advertising, it doesn't hurt.
Old 11-25-2020, 02:41 PM   #18 (permalink)
10-degrees
Could the 10-degrees have anything to do with SAE departure angle clearance requirement for that overhang ?
IRONICK (11-26-2020)
Old 11-25-2020, 03:51 PM   #19 (permalink)
No-one has explained to me whether the x-degree angle is at the leading edge, trailing edge or average of the camber.
Old 11-25-2020, 03:55 PM   #20 (permalink)
It doesn't have to be cambered. Mine on the Insight is non-cambered after the undertray/diffuser transition, so the 10 degrees (approx) applies to the inclination of the straight panel.
freebeard (11-25-2020)
