Old 11-30-2020, 07:47 PM   #31 (permalink)
IRONICK's Avatar
Originally Posted by marketroid View Post
Yes, thanks. I've got those sitting in my basement waiting for me to install them as well.
Until the deflectors from the Golf 8 appeared (to match PnP), I used BMW parts. They have a larger surface, more curved and capture the air better in the front.
Old 12-01-2020, 12:36 AM   #32 (permalink)
Did you start with a stock part for your front arm covers (vwforum.ro/topic/135866-golf-7-imbunatatiri-aerodinamice-si-nvh-noise-vibration-and-harshness/?do=findComment&comment=3015589) or were they entirely custom made?
Also, any idea what the part number is for the "Rear axle cover with gurney spoilers" for the e-tron Sportback 55 quattro (vwforum.ro/topic/135866-golf-7-imbunatatiri-aerodinamice-si-nvh-noise-vibration-and-harshness/?do=findComment&comment=3016344)? Do you think that might work for the eGolf?
Old 12-03-2020, 05:32 AM   #33 (permalink)
IRONICK's Avatar
Fully customized. They are not perfectly bent, I did not have the patience to make a mold for bending the edges.
Please let me study a little.
Personally, I would build it manually, it will come out ten times cheaper.
By the way, from the e-tron model I would put something else on the face ...
Old 12-03-2020, 05:51 AM   #34 (permalink)
IRONICK's Avatar
It's a bit short, the back is part of the spoiler ...
https://www.ebay.com/itm/Audi-E-Tron...1/264391769448
The Following User Says Thank You to IRONICK For This Useful Post:
marketroid (12-06-2020)
Old 12-03-2020, 06:25 AM   #35 (permalink)
IRONICK's Avatar
Something interesting to read, which confirmed the changes made on the Golf 7 and Golf 8.
https://airshaper.com/blog/volkswage...nd-improvement
COcyclist (12-03-2020)
Old 12-03-2020, 02:58 PM   #36 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Great link. Thanks for posting it. Of course it should be even easier to cover from the axle back on the eGolf because there is no exhaust piping or exhaust heat to deal with on an all electric car.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 12-03-2020, 03:17 PM   #37 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
This is what I did on my car. It is a diesel so I have not had much of a problem with the coroplast covering the exhaust. It has sagged slightly over more than 10 years since I installed it but some of that may be due to trapped snow/ice and water from winter driving.
TDi=fast frugal fun
The Following 3 Users Say Thank You to COcyclist For This Useful Post:
aerohead (12-04-2020), marketroid (12-06-2020), woodstock74 (12-05-2020)
Old 12-06-2020, 11:19 AM   #38 (permalink)
Yeah, doesn't look as plug and play as I was hoping...
Old 12-06-2020, 03:26 PM   #39 (permalink)
IRONICK's Avatar
You will not find anything plug and play.
Old 12-07-2020, 10:05 PM   #40 (permalink)
A guy can dream, can't he?
The Following User Says Thank You to marketroid For This Useful Post:
IRONICK (12-08-2020)
