Old 11-10-2014, 09:03 PM   #1 (permalink)
Tinkerer
kafer65's Avatar
Silver - '15 Mazda CX-5 Sport
Team Mazda
90 day: 37.23 mpg (US)
mirror delete with integeated blinkers
My to do list includes side mirror deletes. They are next to useless and I use the rearview spot mirror to deal with the huge c-pillar blind spot i have now anyway. My primary concern is that they are mounted to the door skins not near the a-pillars. Second problem is integrated blinkers. If I remove one will I have to put a resistor in to spoof the electrical circuit to blink at the right rate or will it act like a bulb is out and blink too fast? I found a good diy for getting after the bolts that hold it on. finding time block to make a plate that i could bolt back in is also holding me back. Any insights from the gurus are welcome.
Mirror deletes, 80% grill blocks, wheel covers, 50 psi tires = 6% better MPG avg. over a year. Wheel skirts overcoming ethanol winter fuel mpg losses and more!
http://ecomodder.com/forum/showthrea...ead-30641.html
Old 11-10-2014, 10:56 PM   #2 (permalink)
Heh. I thought that you were going to put a turn signal into the flat plat with which you were replacing your mirrors!
Old 11-11-2014, 05:57 AM   #3 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
You want to deliberately remove your indicators?
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
Cobb (11-11-2014)
Old 11-11-2014, 08:20 AM   #4 (permalink)
From the mirrors?
Old 11-11-2014, 11:23 AM   #5 (permalink)
Tinkerer
kafer65's Avatar
Team Mazda
I want to remove the mirrors but they have EXTRA blinking indicators on the outside tips of the mirrors. I also have conventional indicators at the front and back lamp assemblies. I want to put flat plates over the mirror's point of entry into the door. It will not have a blinker in the plate. It would look like what was done on the Prius mirror delete thread.
I'm wondering if I do this will it cause the remaining indicators to blink too fast, since I will be removing a bulb from the circuit. That's assuming that the outboard mirror indicators are on the same circuit as the conventional front and back blinkers. They may be LEDs out board too.
Once I commit to removing them its going to take some time to make a cover over the whole and I don't want to leave it exposed to rain in the mean time.
I'm brainstorming at this point with the nagging thought that this may be disturbing a module somewhere. Attempts to modify the rear hatch dome light (its easily covered by gear since its on the side panel not the dome)came with warnings of module damage.
Old 11-11-2014, 11:23 AM   #6 (permalink)
Dark Egg - '12 VW Touraeg
The turn indicators in the mirrors are LED and the car would never know they were gone. You could add side European style turn indicators if you were worried about the loss of indication but it is not required in the US. Now side mirrors on the other hand I think are required and of course government so slow to react to technology doesn't recognize electronic "mirrors".
Old 11-11-2014, 11:31 AM   #7 (permalink)
Tinkerer
kafer65's Avatar
Team Mazda
Tennessee law requires a rear view mirror but is vague and doesn't specifically call for side mirrors. I'm sure I'd get pulled over anyway if I didn't have one on the drivers side. I used a bicycle side and rear mirror in my sandrail for close to a decade without complaint. They were only irritated that my teepee exhaust wasn't quite enough.
