Old 10-30-2013, 06:00 AM   #1 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
Early model Focus mpgs?
I have a 2003 Focus ZX3 that in summer might do 36 mpg in mixed driving and around 38 mpg highway. According to the sticker under the hood...this car is both a PZEV and a ULEV...meaning a California car with stricter pollution standards for the year.
A neighbor bought a 2000 Focus sedan and claims to get 38 mpg around town and 44 mpg on a long trip. No mods...high mileage(?)....no real attempt to drive for mpg???
Both cars have an auto trans and I assume the DOHC engine.
A search of the GARAGE for Focus brings up some that do almost as well..but not many....
Looks like the stricter pollution standards cost mpg?
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
Old 10-30-2013, 09:47 AM   #2 (permalink)
DFCO means the car is a PZEV, since it is moving and consuming no fuel in DFCO.
regards
Mech
Old 10-30-2013, 12:26 PM   #3 (permalink)
You're doing pretty well. I had a 2002 ZX5 5-speed and I averaged between 27-34MPG most of the time.
Old 10-30-2013, 01:18 PM   #4 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.65 mpg (US)
Not a valid comparison. Driving technique is more significant than most people realize. My experience is that smooth on the throttle (DWL) plus coasting instead of using the brakes (DWB) was worth 10% gas mileage.
Old 10-30-2013, 04:14 PM   #5 (permalink)
EtOH
Allch Chcar's Avatar
Cordelia - '15 Mazda Mazda3 i Sport
90 day: 37.83 mpg (US)
There were at least 2 base engines for the first gen Focus. The 2.0L SOHC split port and the 2.0L DOHC Zetec. The Split port is rated for higher MPG from lower cam profile and taller gearing. ZX3 and ZTS had the Zetec standard. While the LX and SE came with Split port standard but Zetec was an option. Not only do the PZEV engines reduce HP, Torque, but also MPG.
There was a high output version of the Zetec available on SVTs. Then there was the 2.3L Duratec in the faux "ST" for MY '04-'05 and the new 2.0L Duratec base engine from MY'05 on.
-Allch Chcar
Old 10-31-2013, 07:16 AM   #6 (permalink)
Her car might have the SOHC engine. This engine tends to lose valves...if you look at used engines of both types...SOHC and DOHC...you find that the SOHC are much more costly...while the DOHC are cheap and easy to find...long lasting.
After about 03...the early model Focuses are almost as reliable as Toyotas/Hondas of the same period...according to ConsumerReports. Current models rate more poorly.
Main gain with the Cali car is the lack of rust. I like the Focus...with the rear suspension mounted in rubber and the engine the same it doesn't have that economy buzz you got with the older small cars. With minor mods it also handles well.
Old 10-31-2013, 04:32 PM   #7 (permalink)
EtOH
Precisely,my guess is hers is the SOHC due to better MPG and especially since it's a LX. I looked at first gen Foci and found that out pretty quickly how the sedan usually ends up with a blown engine. The Zetec is pretty reliable and the Duratec is even better(timing chain etc). But there is no shame in owning a Zetec.
The current Focus is having problems with the AT and Sync. Get one without Sync and with the newest MTX75 if you ever go that route.
-Allch Chcar
Old 11-03-2013, 01:15 PM   #8 (permalink)
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
I really like my 2000 Ford Focus. Wish I had a model from later in the generation 03-04 because they worked out some of the kinks by then. Real nice car in the price range though.
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
Old 02-18-2014, 08:05 PM   #9 (permalink)
live, breath, Isuzu-Ds
trooper Tdiesel's Avatar
puddle jumper - '93 Suzuki sidekick base model
energizer bunny - '86 isuzu trooper base model
Clifford the big red dog - '84 GM S-10 durango
its a given that the base LX 2000-2003 is a SPI engine.
i fixed one focus that was a SE with the SPI and the valve seat failure, but they're re not very commonen in the SE.
ive seen one wagen model with a SPI
find one thats not blown yet put a new after market head on it and it will last...finding a short block after its gone thats a bugger to do on a budget...
as when they go, scaring or cracking a piston liner from a con rod coming loose from a piston is rather common.
ive got a LX 4 door with the SPI, tall geared manual and the only model to get 14" rims, orignal road rating was 36 mpg
engine heat is a 2 fold friend/enemy. to little heat and it loses mpg, to much heat and thats the most common reason for the valve seat failure.
the ford contour or one of its clone's uses the same odd 4x108mm lug pattern and is the only source of used 14" alloy rims ive found so far. im still on the hunt for those...
1 86 T\D trooper with rare GEN 3 rods TRANS FIXED NOW DD
1 86 4WD 5sp pup is 2.3L gas, but plan on 2.2L diesel repower
1 91 trop, long term plan is a group buy of imported Isuzu 4JB1-T 2.8L I-4 engines, hoping to get price down to 2K not 3K plus
1993 sidekick my MPG toy, epa rating 26.
i get 29/31 with stock drive train.
