Old 10-31-2012, 05:54 PM   #1 (permalink)
CherryBaby - '94 Chevy Camaro
Talking The Easter Egg
Hi everyone new here, looking forward to getting started. I've referenced your site many times since the purchase of my 98 Chevy Metro. I purchased it 2 summers back for a seasonal car for a job, after driving it through the summer and seeing the savings in comparison to my Nissan, I decided to make it my primary source of transportation.
Since the purchase of the car took it through a hot summer in OK, blew a had gasket due to some mechanical issues from initial purchase, hauled it back home and have rebuilt the motor from the bottom up. Since then achieving a life avg. of about 50 w/o 4th gear. So there is much in store and ahead in my echo offing adventures!
Old 11-01-2012, 09:52 AM   #2 (permalink)
90 day: 51.82 mpg (US)
4th gear is over-rated!
Feel free to make a garage entry and start a fuel log:
Your Garage: [ Add new vehicle ]
Welcome to the forum!
Old 11-01-2012, 11:45 AM   #3 (permalink)
Welcome to the site. 50 without 4th gear is pretty impressive, nicely done.
Old 11-02-2012, 12:16 AM   #4 (permalink)
Thanks guys, looking forward to it. The next big change is to find another transmission, I'm hoping to find a donor car with a bad motor. From what I've seen out here I can typically pick one of those up for about the same as a used transmission. Wanting to find an older one for less weight.
Old 11-02-2012, 09:03 AM   #5 (permalink)
If you're hunting for a new transmission, I'm sure you know about the final drive gearing between different years/models of this car. The most efficient "cruising" option (tallest final drive) is in the older Suzuki Swift 1.3 SOHC cars.
Project 'nerd gear': taller tranny transplant nets +5.2% MPG - MetroMPG.com
Old 11-05-2012, 07:12 PM   #6 (permalink)
I've looked into and considered the the taller final drive of the 1.3, a bit concerned that in Utah I often have to climb and that I would find myself down shifting so often that it wouldn't be a benefit.
