Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 12-02-2017, 12:24 AM   #41 (permalink)
puddleglum's Avatar
Rondo - '07 Kia Rondo EX
Last 3: 20.47 mpg (US)
Tinkertoy2 - '00 Toyota Echo base
Last 3: 46.03 mpg (US)
I don't think the BMS limits current, or at least I haven't yet been able to trip it. It mostly seems to have a high and low voltage cutoff.
Good to know. Are you using the packs as they come or re-configuring them? Have you found the sellers specs to be accurate?
Almost all my driving is done 1-5 miles at a time.
Best short trip: 2.4 l/100 km, 3.9 km
Old 12-02-2017, 01:03 AM   #42 (permalink)
90 day: 39.99 mpg (US)
I have reason to believe they're the cells they're supposed to be, but given the prices, my guess is that they're probably used, or maybe rejects for one reason or other. Even so, I find the packs to have similar capacity, and I regularly draw ~16-17A (per pack) without causing noticeable heating or any other issue so far.
I've left the 10S config as-is because I don't want to replace the BMS. My trike currently has the packs in a 2x3 (or a 20S3P cell) config, and my controller is configured not to exceed 96 amps or 3000w, whichever is lower.
puddleglum (12-02-2017)
ebike, solar panels
