Old 01-22-2008, 11:40 PM   #1 (permalink)
One of the few....
Estimate of mpg gain?
Hey all. For those that haven't read my introduction, I drive a 1994 Jeep Wrangler. It is the 4 cylinder, 5-speed model and has betwen 130,000 and 140,000 miles on it. When I first got it, it was averaging me anywhere from 13 to 15 mpg. Since the EPA estimates for it are 17 city/18 highway, I've been checking into the usual maintenance items and replacing as needed. Thus far, I've done the plugs, wires, cap and rotor. I plan to do the fuel filter and air filter within the next week or two.
Basically, my question is that if I manage to get the thing running peak again (approximately meeting the EPA estimates) about how much more of an efficiency/mpg improvement could I expect with the following mods?
  • Partial grill block
  • Air dam
  • Synthetic lube in the engine, transmission and differentials
  • Heat-resistant exhaust wrap
  • Folding in or removing mirrors
  • Airing tires to max
  • Keeping highway speeds to 55-60 mph
That is pretty much my big list of ideas for the Jeep. I just wanted to see what you guys thought I could gain from that. Thanks for any and all help.
Old 01-22-2008, 11:41 PM   #2 (permalink)
+2 mpg
Old 01-22-2008, 11:47 PM   #3 (permalink)
90 day: 51.82 mpg (US)
What highway speeds do you currently drive, and how much highway driving makes up a typical tank? (Depending on your starting point & amount of hwy use, that may be where you'll get the biggest improvement.)
Old 01-22-2008, 11:54 PM   #4 (permalink)
One of the few....
Normally I drive about 70 mph, and a typical tank is usually around 60% highway/40% city.
Old 01-23-2008, 07:59 AM   #5 (permalink)
OK. Then "Keeping highway speeds to 55-60 mph" will probably give you the single largest % improvement of the items you listed (though they'll all help - don't get me wrong).
I'm guessing a 20% minimum improvement, combined. That would take you from 14-17 mpg, approx.
You should make a garage entry for the Jeep & start recording your fill-ups so we can see how it progresses.
Test: Alternator vs. no alternator = 10% MPG gain @ 70 km/h MetroMPG EcoModding Central 450 10-27-2023 09:40 AM
Finally: 100 mpg (US) round trip in the Blackfly - new and improved: 133 mpg MetroMPG Hypermiling / EcoDriver's Ed 12 11-02-2012 05:08 PM
BBC reporter drives the new VW Polo Bluemotion 566 miles, gets 50 mpg (US) MetroMPG General Efficiency Discussion 1 04-08-2011 10:58 AM
Equivalent MPG of cycling - garage feature? MetroMPG Alternative Transportation 21 12-27-2007 01:57 AM
Article: 57 mpg? That's so 20 years ago SVOboy General Efficiency Discussion 17 12-23-2007 09:56 PM
