Old 07-24-2017, 04:56 PM   #311 (permalink)
Master procastinator
Turan turan - '09 Volkswagen Touran Freestyle
Combot - '04 Opel Combo Tour
90 day: 40.37 mpg (US)
How about sleepin' in the wagon?
Old 07-25-2017, 12:20 AM   #312 (permalink)
I never tried to sleep in a wagon, but I'm sure a van would be more comfortable on that matter. Well, even though I usually like wagons more than sedans, nobody can deny that vans are by far the most practical type of vehicle.
Old 07-25-2017, 11:36 AM   #313 (permalink)
Volvo-driving MachYeen
Fingie's Avatar
Neo Volvo - '98 Volvo S70 10V
90 day: 24.98 mpg (US)
oh no, War wagon is good to sleep in, even if i have to bend my legs.
But a trailer that could be equipped with a bed and a heater would be more comfy IMO
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
Old 07-25-2017, 11:54 AM   #314 (permalink)
Fingie's Avatar
Hmm, i wonder if i could wrap a copper pipe around the exhaust pipe in War wagon, and run two small hoses to the trailer and install a small radiator in it, while having a small pump. maybe have the spiral go through a water reservoir for drinking water?
so when i park i would have a warm trailer and water
a crude paint thingy Click image for larger version
Name:	lada heater pump.jpg
The Following User Says Thank You to Fingie For This Useful Post:
Joggernot (07-25-2017)
Old 07-25-2017, 01:43 PM   #315 (permalink)
Not sure if that exhaust-heated setup would be so easy to implement, and to keep the hoses safe from punctures due to debris on the road.
Fingie (07-25-2017)
Old 07-25-2017, 02:26 PM   #316 (permalink)
Fingie's Avatar
haha, true.
Old 07-28-2017, 03:17 PM   #317 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
I considered a similer thing(trailer heat) with my 5th wheel .
I thought simpler and easier than exhaust , engine coolent. Less chance of stoping to find my cats and dog CO2ed after 12+hrs on the road.
Add .5"return and .75"feed pipe (isolated) to the rear bumper use hydraulic quick disconnect(QD), they seal both male and female unlike air QD, and a slinky hose to a set of QD on the trailer , heater core from a 15 passenger van.with a 12v fan blowing into the floor duct for the stock heater. Before someone says ,Why not just use the heater that came with the ducting? This was a transit problem can't use the furnace @55mph ,keeping the water lines and tanks(60ga fresh, 2x20gray, 40 black) from freezing during winter travel over Donner Pass and others below 0f at times. But life changed and I didn't get that far with the idea.
For exhaust a 2"+ umbilical cord would be needed,and high mounted to give enough slack /flexibility for turning. Do you have a catalytic converter? If so that would be my sorce of heat. 600-800°f a cat starts to work .by the time you got to the trailer it should have cooled sufficiently. Passive or forced air?
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 07-28-2017, 11:54 PM   #318 (permalink)
A heat-exchanging setup based on coolant fluid recirculating between a trailer-mounted heater core and the exhaust muffler might not really become a danger for carbon monoxide poisoning, but anyway, it would still require thermostatic control to not become excessively hot. Similar setups have been adapted into trucks repowered with air-cooled Deutz engines.
Old 08-05-2017, 10:03 AM   #319 (permalink)
Fingie's Avatar
CV joint on the left sh*t itself, started to make noise.
removed the rubber boot, but didn't get the joint off.
finally put it together and drove 25 miles to my friend's workshop with a dry, beaten cv joint. Was funnily quiet the whole trip
also found out a brake pad was stuck, and completely worn out.
bought new pads.
the whole ordeal cost me 60 bucks to fix though not so expensive, thankfully
Old 08-13-2017, 08:43 AM   #320 (permalink)
Fingie's Avatar
changed the oil to the same brand i have used now, but now it has "fuel saving" tech. We'll see lol if it makes a difference
