Old 12-10-2015, 07:09 PM   #41 (permalink)
Volvo-driving MachYeen
Fingie's Avatar
Neo Volvo - '98 Volvo S70 10V
90 day: 24.98 mpg (US)
Well, UAPC has worked quite well for now. Next mod i've thought about is installing LED DRLs in the grille. Also some smoothing of the lines in the could also be a good start.
3 weeks and 2 days until my mandatory military service, i'm getting a bit nervous
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
Old 12-29-2015, 11:08 AM   #42 (permalink)
Fingie's Avatar
Military service starts 4 january. I tried to fix the priming problem but i gave up for now. I installed a switch so i manually use the fuel pump.
Weirdly ebough, the pump does not need the switch when the car warms up
Old 01-07-2016, 02:35 PM   #43 (permalink)
Fingie's Avatar
I am in military service now, so i will be pretty much absent.
Old 03-24-2016, 07:44 AM   #44 (permalink)
Fingie's Avatar
Here's my babe under work.
The Following User Says Thank You to Fingie For This Useful Post:
Joggernot (03-24-2016)
Old 03-24-2016, 07:45 AM   #45 (permalink)
Fingie's Avatar
Side view
Old 03-24-2016, 09:25 AM   #46 (permalink)
Joggernot's Avatar
Originally Posted by Fingie View Post
If you do not make small mistakes in life, life itself will be a F**kup
I like your signature.
The Following User Says Thank You to Joggernot For This Useful Post:
Fingie (03-24-2016)
Old 03-24-2016, 10:19 AM   #47 (permalink)
Fingie's Avatar
I came up with it when i was home, i messed up a computer
Old 03-24-2016, 10:19 AM   #48 (permalink)
Fingie's Avatar
Feel free to use it as a quote
Joggernot (03-27-2016)
Old 03-27-2016, 02:48 AM   #49 (permalink)
What were you doing?
Old 03-27-2016, 07:49 AM   #50 (permalink)
Fingie's Avatar
I was checking oils, re-connected the battery as UAPC hadn't been driven for two months. Runs nicely,but i should chamge the ignition switch, as it's the reason why it doesn't prime the fuel pump. Manual switch will do for now, military service eats my weeks away.
