Old 07-02-2013, 12:58 PM   #1 (permalink)
Edu's WICFTIL Electric Conversion
So, I finally decided to start my thread, so far it's title is "Edu's WICFTIL Electric Conversion" WICFTIL stands for "whatever I can find that I like".
After I read Project ForkenSwift thread and Ben Nelson's Metro Build thread plus watching his dvd, I decided to start my own conversion.
Phase 1 was to find a place where I could work, since my wife, my two cats and I were living in a flat we had to move to a bigger place with garage.
Now, I have to decide what should I get first the car or an electric motor.
I've been looking for around 7 months and I couldn't find a place here in Switzerland where I could get a forklift motor, I think that its gonna be the most difficult part, I might need to get it somewhere else and get it send here, maybe if I find something on the UK I could go there for a weekend and get it.
About cars, I'm not sure which one should I go for, I have a few that I like:
smart - it's small, relatively light and there are a few around with a blow engine that goes for $500 CHF ( for swiss price its not that much ). On the down side there is no repair manual available for it.
vauxhall/opel/chevrolet corsa around '98- I like that one very much, I had one before and again it's a light car.
suzuki swift - I think that would be the easier to do because it has been done before and I can find info here about it.
Can you guys give me your opinion, what car do you think I should go for, I've seen a thread in another forum about a smart conversion, but the guy changed a lot of stuff like gear box and so on, though I think a smart would be a nice conversion I don't want to start with a difficult conversion.
thanks.
I'm looking forward to your feedback
The Following User Says Thank You to mocadnet For This Useful Post:
MPaulHolmes (07-02-2013)
Old 07-02-2013, 01:57 PM   #2 (permalink)
90 day: 57.73 mpg (US)
Welcome!
Smart is more difficult because there isn't much capacity (space or weight) for batteries. However if you're only looking for a short-range runabout, it's not as much of an issue. Also, is a manual gearbox available in the Smart? Here it's only an automated manual, and that makes doing a conversion more difficult.
Biggest advice: don't get a piece of junk donor car. Even if the price is right, you will just end up with a piece of junk EV.
Ask me how I know this.
Old 07-03-2013, 03:27 AM   #3 (permalink)
thanks for the advice, I check it and there is no clutch, so, smart is out of my list.
That is my biggest worry, here snows a lot and they put a lot of salt on the streets I really need to check very carefully to avoid ending up with a rust piece of crap.
How do you know this?!?!
My initial idea is to have a 72v system, I just want to drive to the train station, supermarket, and around the region.
Old 07-03-2013, 11:24 AM   #4 (permalink)
72v should be fine for a light weight runabout.
48v is only barely adequate in mostly flat terrain if I avoid the "main" roads. Too slow (at least with 400A and ~2000 lbs). Not enough power for steep hills.
