Old 05-04-2019, 02:40 AM   #1 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Effects of killing one injector - 4 cylinders
Odd thought as my googling was unsuccessful. With a lot of real world experience with friends running Hondas basically tractoring down the road with one dead cylinder, two dead cylinders, and one time an amazing three cylinders down. What would killing one cylinder do? I assume if you killed the injector to keep the fuel from pumping instead of just killing the spark like what typically happens... Could you three cylinder it and get better mileage?
DIYactivecylindermanagement?
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 05-04-2019, 04:28 AM   #2 (permalink)
90 day: 55.9 mpg (US)
The 'dead' cylinder would pump fresh air into the exhaust, so the lambda sensor will sense an overage of oxygen and the EFI computer will try to compensate by injecting extra fuel into the other cylinders.
So just disconnecting the injector is no good.
However, if you close off the intake port of the dead cylinder that will be drawing a vacuum instead of pumping air. That way it has as little friction as possible. Then it would run more or less smoothly.
The vacuum will draw some oil into the cylinder head. Maybe it seeps back into the oil pan when the engine is at rest, otherwise the buildup may cause trouble.
Old 05-04-2019, 06:47 AM   #3 (permalink)
Should be simple enough for you to pull the wire off an injector and run it. If the CEL freaks you out stuff a resistor in the connector.
Old 05-04-2019, 09:27 AM   #4 (permalink)
It only works in engines with hydraulic lifters.
Old 05-04-2019, 11:39 AM   #5 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
Odd thought as my googling was unsuccessful. With a lot of real world experience with friends running Hondas basically tractoring down the road with one dead cylinder, two dead cylinders, and one time an amazing three cylinders down. What would killing one cylinder do? I assume if you killed the injector to keep the fuel from pumping instead of just killing the spark like what typically happens... Could you three cylinder it and get better mileage? DIYactivecylindermanagement?
For cylinder deactivation to work you need to keep the valves closed on the deactivated cylinder. If you don't close the valves you increase the pumping losses of the engine. (You are essentially using that dead cylinder as an air compressor.) Pumping air also causes all kinds of problems with the engine management as noted by RedDevil
Plenty of overhead cam engines have cylinder deactivation. They use two piece rocker arms with a pin connecting them. When the cylinder is in use oil pressure keeps the two pieces pinned together allowing the valve to open in close. When the cylinder is deactivated the pin is disconnected so the cam is not longer connected to the valve.
EDIT: Eaton's overhead cam cylinder deactivation
http://videos.eaton.com/detail/video...tion-with-lash
Old 05-04-2019, 05:10 PM   #6 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
That alone would stop me from trying this on a Prius, since the 2010s and 2011s are already known to be prone to developing oil-burning issues as they age.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 05-04-2019, 09:23 PM   #7 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
My Fit lost an injector a year and a half ago. It was scary, I didn't think I'd make it up a couple hills no matter what gear I was in. Maybe it was the limp mode, but I don't want to see that again.
Transmission type Efficiency
Old 05-05-2019, 11:21 PM   #8 (permalink)
Wanting more for less
D.O.G.'s Avatar
Metric - '94 Honda Magna 250
Motorcycle
90 day: 69.83 mpg (US)
RedCelica - '94 Toyota Celica ZR
90 day: 35.97 mpg (US)
i30 - '12 Hyundai i30 Elite
90 day: 39.84 mpg (US)
i30-22 - '12 Hyundai i30 Elite
90 day: 39.22 mpg (US)
One of my wife's previous cars (Holden Gemini from many years ago) snapped the camshaft in half so it only operated the valves on the front two cylinders.
It ran on the flat, but wouldn't go up hills. Living in the mountains as we do, it meant getting the car towed home.
Old 05-07-2019, 07:14 AM   #9 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
My FIAT runs great on 2 cylinders. I have had it on one cylinder (coil pack failure) and it still went well enough.
Old 05-07-2019, 08:45 AM   #10 (permalink)
Yeah I'm not one to try it on the Prius. Car is too nice to be doing hanky mods. Makes me want wanna do a catch can but my car only burns like 1/2 to 3/4 quart over 10k. Considering what most of my American cars have used over 7.5k that's fantastic. 😂
What about your car? I mean on the worst end of the scale I went 12k on walmart syn and never had to add any oil. Still up halfway on the stick.
