Old 08-19-2014, 07:56 PM   #1 (permalink)
Gasoile's Avatar
Tsonas - '06 Smart Roadster
90 day: 47.03 mpg (US)
Efficiency and optimization psycho
Hi everyone!
I'm an electronic engineer student currently developing a project of a device to reduce fuel waste on a drive-by-wire car for my MSc thesis.
Now that I found out this forum I hope to contribute as much as possible to hack into ECUs for a greater eco-experience
Old 08-19-2014, 08:01 PM   #2 (permalink)
...beats walking...
Howdy!
Study the CODING within most automotive ECU's and you'll find MOST emphasis is upon "handling of exceptions", such as: (a) ignition retarding when gasoline of lower octane (than required) is used; (b) high-altitude "thinning of air" requires totally different MAP measurements of air flow, etc.
Old 08-19-2014, 10:30 PM   #3 (permalink)
I think substantial gains could be had by electronically smoothing the spasmo throttle inputs of the average idiot.
P.S. And not allowing braking while accelerating with the engine and vice versa.
The Following 2 Users Say Thank You to Frank Lee For This Useful Post:
MetroMPG (08-20-2014), niky (08-19-2014)
Old 08-20-2014, 12:45 AM   #4 (permalink)
Gasoile's Avatar
In my perspective, car companies are trying to make more efficient cars focusing on hardware optimization, but the software beyond that shiny hardware is far from perfect.
Old 08-20-2014, 11:20 AM   #5 (permalink)
90 day: 51.82 mpg (US)
Welcome.
Julian Edgar did a simple "idiot smoothing" modification to his first generation Honda Insight simply by adding a capacitor in the throttle position sensor that helped that car's efficiency.
AutoSpeed - Giving the Insight a Good Driver
Gasoline Fumes (08-21-2014)
