Old 05-21-2020, 08:46 PM   #1 (permalink)
Electric auxiliary drive for semi-trailers in Brazil
Randon, one of the most prominent manufacturers of semi-trailers and other truck implements in Brazil, now offers an electric auxiliary drive as an option for some of its semi-trailers.
Old 05-03-2023, 04:19 AM   #2 (permalink)
Thanks for linking this in the other thread. I'd missed it in 2020.
I can translate some of that but it's not clear how it's controlled. Is that what EQUIPADO COM E-SYS is about?
Old 05-03-2023, 01:08 PM   #3 (permalink)
90 day: 29.78 mpg (US)
Trailer is where a hybrid or EV truck battery should live. There's tons of empty space under the load deck, and if you've got a reefer, you want the power bank to stay on the trailer to continue cooling it.
Old 05-03-2023, 04:17 PM   #4 (permalink)
https://external-content.duckduckgo....bf7&ipo=images
Old 05-04-2023, 02:03 AM   #5 (permalink)
Not sure if such a hybrid setup would be enough to get rid of the ICE-powered reefer unit in a refrigerated trailer, yet AFAIK Thermo King already makes some equipments resorting to a Diesel-powered genset and an electric compressor, instead of an engine-driven compressor. Adding solar panels could eventually make sense to a hybridized refrigerated trailer.
I don't know how it's controlled, but E-Sys is the commercial nomenclature used by the maker of the trailers fitted with that.
freebeard (05-04-2023)
