Old 07-12-2021, 01:28 AM   #11 (permalink)
Bull****. I've explained some things very clearly but let me be more blunt:
1. I am building a nice, expensive American pickup truck. I am not driving an embarrassing MPG mobile. Nor a wagon, or whatever other ridiculous stupid thing you dig up.
I pointed to the drivetrain section of funkhoss' thread. Mention of the Summit catalog suggests where you're coming from.
I'm sure this conversation is over (to be fair it never started) so I won't bother checking this any further.
Something happened between post #5 and #10. No great loss, but I was waiting to find out if it would be a[n airbagged] C-10 cab.
You can lead a fool to profit, but you can't make him think. --Sandy Munro
Old 07-12-2021, 08:58 AM   #12 (permalink)
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Originally Posted by 48V View Post
I really, really want a 1/2 ton plug-in hybrid pickup truck. First, I want all the engine accessories to be electric. No alternator, just a battery pack. Relatively simple to accomplish.
Second, I want the front wheels to be electrified. It doesn't need to go very fast, just for creeping along in traffic, parking lots, drive thrus, etc with the engine off. It could also provide regenerative braking at higher speeds.
If I start with a generic 1/2 ton 4WD truck (I'm not naming a brand on purpose) what would be the best way to try and accomplish this? I would like to get rid of the transfer case but keep the front axle.
What size motor would I need to do such a thing? Could I do something as simple as attaching a ~10hp electric motor to the front driveshaft, or directly on the differential? I'm not really sure how much power I would need, or what options are out there. I would prefer to keep the whole thing running on 48v if I can...
Thoughts?
Traction motor:
Motor size would depend on gear ratio and desired speed and acceleration. For creeping long in traffic you could possibly get by with a 10hp motor connected to the front drive axle. But you'd either need a way to disconnect it when going faster than a crawl or a bigger motor.
The thing is that in order to get enough torque you'd need to gear the 10hp motor down. But if it's constantly connected you would over-rev it and blow it up when going a faster speed. So you need a clutch to disconnect it. Of course if you use a clutch and disconnect it at higher speeds you wouldn't have any regenerative braking. So you need a motor that will rev up high enough and that's powerful enough so that the gearing (in the differential for an example) won't make it have so little torque it won't move the vehicle.
Motor type is also important. Series wound motors can have very high torque at low speeds and not have to be very powerful over all to do so. But it is very difficult (just consider it impossible unless you're an expert) to do regen in a series motor.
Accessories
Of course, for your accessories to be powered by electricity you'd need an electric motor that turns the accessories. But it would either have to match the voltage of the main motor, or you'd need separate batteries, one for the main plug-in hybrid, and one for the electric accesories.
If done right you wouldn't need an alternator (use the high voltage traction battery to power a DC to DC converter to charge the 12V system). So you could remove the alternator and put in place an electric motor that runs off the high voltage traction battery and route the accesory belt so it dpesn't connect to the crank pulley (or put a free wheeling pulley on the end of the crankshaft). That way it could run your A/C, power steering and water pump.
To make it even more efficient you'd hook up an electric motor to each of those separately, one for the A/C, one for the power steering and one for the water pump. That way, you only get power steering when you need power steering, or pump water only when you need to pump water to cool the enigne or heat the cabin, etc. Of course then you'd have to re-plumb things like the A/C compressor which needs high pressure tubing.
This is something I have been thinking about for a very long time. Technology is changing so fast it's kind of hard to keep up. Much of it is for convenience and reliability as much as it is for gas mileage. I want to be able to "idle" with the engine off. By that I mean heating or A/C, lighting, or creeping forward. I don't want any belt system on the engine, and it would be useful to be able to run electric water pump and fan with the engine off, or maybe a block heater depending on weather.
There will be an additional gas powered DC generator in the 3-4kw range installed in a toolbox in the bed. Obviously a battery pack, not huge, hopefully around 10kw, and it will also have a 10kw power inverter so it can be used as a mobile generator. With that I can also power 120v accessories like a block heater or air conditioning.
What kind of motors are available that mount to the trans tailshaft? If I did something like that I could simply use a lighter 2WD truck right? (I don't need to go off road) I will likely be using a 4L80E for a trans unless I decide I want more gears. I know GM did it like that but I figured they are kind of rare and hard to find parts, but maybe I'm wrong.
Basically I am building a "new" 20-ish year old truck because I absolutely hate all the new stuff. Maybe it would be easier to just get the factory GM hybrid and make it as nice as I can, but probably not easy to find. I do not want something that has rare and hard to replace components.
Question: What is the DC generator for?
My immediate thoughts (no offense) is that if you have regen and you already have a gasoline (or diesel?) engine you already have a way of charging the high voltage traction battery. If you're worried about running out of electricity and hurting your HV traction battery at a stop you could also put a generator on the engine and just start up and drive normally under gasoline (or diesel?) power. The generator would add more weight and could possibly be less efficient than the engine you already got.
Heating with the engine off (unless you just drove and are using residual engine heat for a short time) will use a lot of electricity, especially with the HV battery suffering the effects of the cold. One thing that can help is installing (if you don't have it already) and using heated seats. It's much more efficient to heat your body directly than the whole cabin. Of course that doesn't do much to defog the windshield.
A "10kW" battery is a measure of power. I'm not sure that would be enough power, even with a 10hp motor. Once you factor in some 3-5kW of heating the cabin or some 3kW to run the A/C you'd not have very much power left over, especially in the winter.
Maybe you meant "10kWh", a measure of energy. That sounds reasonable.
What motor? Well, this is where you kind of are on your own, because this kind of thing isn't done very often (you may be the first to do such a conversion, at least on the model of truck you're looking at). I'd suggest researching EV conversion stores. You'd need a custom made adapter to connect it to your drive shaft. So you'd need to higher a machine shop.
Most everything else can be done with off-the shelf parts. Battery cells, connected together with bus bars, cables, battery management system and motor controllers are all common off, the shelf parts. Remember to look for motors and motor controllers that have the same voltage ratings (that can handle the voltages of your battery) if you're hooking up motors for your accesories too.
I suppose you already know the basics of electricity. Each cell has an aceptable voltage range (e.g. 2.5-4.0V) and amount of current (e.g. 20A) If you add another cell in series you add the voltage (5-8V) but if you connect it in parallel you add the current (40A). Then multiply the voltage by the current and you get the wattage (6.5V x 40A = 260W) And ever 1000 watts or 1kW is equal to about 1.34hp. How long it will run at a certain power depends on the energy measured in watt-hours or kilowatt-hours.
2. I've explained I absolutely do not want anything new. If you gave me a brand new truck, and paid the taxes for me, I would sell it and buy an old one.
3. I never said I wanted a full hybrid. The "mild hybrid" part is really easy. Electric fans/water pumps/AC is child's play in 2021. I can literally buy all this stuff straight out of a Summit catalog and it's designed to bolt up to my engine. And it cost almost nothing.
4. As far as movement is concerned, I want less than 10mph. That is not a big ask. There are many different ways this could be accomplished, I was simply curious if anybody else had done it. Obviously that takes very little HP, and thus, 48v would be absolutely fine. Maybe even 24.
5. I already explained I do not care about gas mileage. I want a truck that is functionally superior, I couldn't care less how much gas it uses. In fact, it will be getting a 100 gallon tank. Again, as I already said, this truck will be a mobile generator, and has features that are nicer than you will find in something from the factory. There are other reasons for hybridization beyond saving a few cents worth of gas.
6. I'm not poor. I could go to the dealership and take any car they have. Again, I have not seen any current models I want anything to do with. Thus, I make the car I want. Not my first rodeo.
Hey! Nobody's forcing you to do anything. Nor can we read your mind and understand all of your goals here. I don't even know what exactly you mean by "functionally superior...
I do see problems using an automatic transmission. You don't want to just pop it in neutral and shut off the engine and use the EV motor to move the truck. You would soon ruin your transmission because it would be turning without any lubrication (pump would be off). You'd need to either install an electric hydraulic pump or have a way (transfer case?) of disconnecting it completely. Or go the stick shift route.
Old 07-12-2021, 09:14 AM   #13 (permalink)
There are double ended shaft motors. One that comes to mind is the Warp 9 Motor 32.2HP. But it's series wound (no regen) and you'd have to make your own adapters to connect it to your transmission and driveshaft.
Maybe I'm wrong, but I would think that a chain drive from the motor to a sprocket welded to the U joint on the transmission output shaft would be the easiest route. Then, as long as you have room, you could just put a sprocket on any electric motor you so desire and weld up some brackets to hold it in place.
But again, if you want a little 48hp motor you'd have to use a very small sprocket on the motor and a very large one on the drive shaft to give it enough torque (geared down) to move the truck. But then it would explode from over-revving at higher speeds unless you have a way of disconnecting the motor from the driveshaft.
Maybe meet in the middle with something like this: https://www.kellycontroller.com/shop/mars-0913/
It's got 30kW peak power at 96V and could power your truck at low speeds while being geared to the drive line high enough so as not to over-rev and explode at higher speeds. It could also regen for you at higher speeds.
On the other hand I did see this motor, also a Warp 9, with a u-joint output shaft: https://www.electriccarpartscompany....-9-ev-dc-motor This motor could possibly be mounted in place of the transfer case to the front axle with less modification than any other motor that I know of. It is also double ended so if you did have a machinist make an adapter you could mount it on a 2WD truck to the transmission and connect your drive shaft to it.
Old 07-12-2021, 10:05 AM   #14 (permalink)
Ruint Taco - '19 Toyota Tacoma SR Double Cab
90 day: 23.76 mpg (US)
Wow.
The Following 2 Users Say Thank You to Vwbeamer For This Useful Post:
Isaac Zachary (07-12-2021), S Keith (07-12-2021)
Old 07-12-2021, 10:28 AM   #15 (permalink)
And it is possible to regen a series wound motor: switching the field out of circuit and exciting it with low control voltage but that technically makes it a sepex. My kostov does it with the interpoles until the field current dies, maybe a couple of hundred yards on the freeway but not a lot of watts.
Not to worry, the initial irritation has gone.
Isaac Zachary (07-13-2021)
Old 07-12-2021, 11:13 AM   #16 (permalink)
The numerically highest gear set I know of for a front axle is approximately 6:1. With a series wound DC motor it should work, but you are looking at more like 30hp and up. But all the good motors are at least 98v and up.
Old 07-12-2021, 01:13 PM   #17 (permalink)
1. You asked a question on an internet forum from a position of obvious ignorance. There are those that want to steer you away from an absurdly expensive underperforming solution. They will voice their opinion. You shouldn't react like a child throwing a titty fit. You should consider if you have the temperament or patience for a project of this scale.
2. Fair.
3. Clearly exhibiting your ignorance here.
4. More ignorance when coupled with claims of #3.
5. The ignorance approaches epic proportion... possibly insanity... you clearly want to spend ridiculous amounts of money for almost no benefit.
6. Good for you. Again, the chest beating and dick-waving suggests you don't have the temperament for a project of this scale.
Bye.
The Following 4 Users Say Thank You to S Keith For This Useful Post:
Isaac Zachary (07-12-2021), mort (07-12-2021), Piotrsko (07-13-2021), Vwbeamer (07-13-2021)
Old 07-12-2021, 09:15 PM   #18 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
The gm hybrid trucks aren't too special with parts, and currently you can get them very inexpensively (spare parts). Just a simple LS engine, a special allison transmission, and toyota NiMH batteries.
Only real point of failure is the battery and afm on the engine, but there's ways around the afm.
Get the denali model and you have about as nice of a truck you can think of.
Simple solution in my mind.
Edit: as it turns out, no high end spec on the trucks, but I suppose you could swap interiors.
The Following 2 Users Say Thank You to ksa8907 For This Useful Post:
Isaac Zachary (07-12-2021), rmay635703 (07-13-2021)
Old 07-13-2021, 01:46 PM   #19 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
From what I’ve been told swapping any year GM Truck drivetrain with any other year GM truck is child’s play, different “incompatible “ years usually fit together with a minor change to the rear xmbr and mounts.
If he wanted 1970’s era sheet metal with a 201X hybrid GM drivetrain it’s probably easy, just a harness and dash frustration
Dodge Flightline (rear axle) is usually 8.x
The ops Idea would be to clone Bens hybrid super truck into a 1/2 ton with an irrelevant random V8
Given the superior gearing available for the rear he could proceed to obtain a Caddillac FWD V8 transaxle (preferably 5mt) and then install an 11” Nissan Leaf A/C motor controller and battery using the universal inverter hack face mounted citicar style straight to the face of the 8.x rear pumpkin.
This would give him the most useful DIY through the road hybrid but costs could still be rather outrageous depending on how much controls background he has.
My diesel suburban imagination conversion would have gone that direction, I already had the 5mt + diesel which turned out to be good enough but then everything rusted out
The Following User Says Thank You to rmay635703 For This Useful Post:
Old 07-13-2021, 04:35 PM   #20 (permalink)
OP wasn't kidding at Permalink #10. We're discussing amongst ourselves.
That said my Lexus axle has 6.78 to 1 reduction and it's capable of 10K RPM. 8 to 1 on a 5K RPM capable motor might be a problem-o.
