Old 01-20-2016, 08:47 PM   #1 (permalink)
time to replace the catalytic converter
Hi Guys
I have to do some exhaust repairs on my 2000 Saturn SC1 -( manuals trans). It's a great car, 40 mpg in the summer, 35mpg winter.
I have to replace the flex joint attached to the down pipe. Unfortunately, It's a welded system. The down pipe, flex joint and cat are all one welded system. So when I do this I figure I will put a new Cat on. Is there a good cat for mileage? Is a performance or hi flow cat worth the money?
thanks
Old 01-20-2016, 09:05 PM   #2 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
First, Do you live in a place where they check emissions?
They do make high flow cats. They don't always work as well as the stock ones.
Old 01-21-2016, 08:20 PM   #3 (permalink)
No. I really don't want to do a cat delete either. If I delete the cat, the down stream O2 sensor will not operate correctly. I detest a perpetual check engine light.
any recommendations? Stock replacement of otherwise?
Old 01-21-2016, 09:27 PM   #4 (permalink)
Dark Egg - '12 VW Touraeg
They sell just the flex piece that you can attach to your existing cat, or you can buy the whole setup with a new cat.
It's Walker 53325 I think for the flex piece and $59 at Rockauto.com Then you can use a universal cat for probably under $100 (I see universal Catco converters on Summit Racing for $70) (or $116 for the Walker Ultra cat at Rockauto)
They whole assembly is about $170 but only the California version shows in stock there (I think it's fine to use a Cal on a federal, just not the other way around if you lived in CA).
If all you need is the flex pipe I would just get it and not replace the converter unless it is actually bad.
Old 01-21-2016, 10:11 PM   #5 (permalink)
Use a spark plug non fowler to cover the rear oxygen sensor.
It will trick the rear sensor into reading the exhaust leaner than it really is.
No check engine light.
