Old 04-28-2012, 02:42 AM   #11 (permalink)
This is my understanding on how these steering columns work.
They are fed by a fairly hefty power wire and earth,and fused with a 60A fuse. They have an ecu with a wire from a speed sensor and a wire from the rev counter plus a fused 3A live and a small earth. The speed sensor varies the amount of assistance. The rev counter wire just tells the ecu the engine is running(I assume so it doesn't drain the battery without the engine running). That's how it works when in the original vehicle.
The controller is just an adjustable potentiometer for the speed signal to vary the assistance.
The system has 3 maps, map 1 is the lowest amount of assistance. When the main power wire is connected without the speed sensor wire the motor works at map 1.
Many people install a 40A fuse as they do not have to turn it up high enough to blow it.
I would assume at its lowest setting(map 1) it would use little power, and would assume a lot less effort than driving a hydraulic pump etc.
Weight wise the column is fairly heavy, but if you stripped your hydraulic stuff out I reckon there may be a weight saving, certainly there would be on an old VW van with the engine in the back! I stripped and weighed my Skyline rear power steering system a few years ago. It had a double pump, one part for front steering, one part for rear. I machined the pump to make it into a front only system and removed half the pump, the lines, and replaced the rear rack with a bar. It all weighed 27KG!
At a guess I would say this system uses an average of 20A at normal driving(nothing when going straight!), so I would say it probably would save fuel. As my van has no power steering I will let you know if I see an increase in fuel use, the trouble is I am also installing a 150A alternator(this may confuse things) as the van has a large stereo(its a party bus!).
I have pics of column if I can work out how to post them.
Ash
Old 04-28-2012, 05:08 AM   #12 (permalink)
Top shaft is the original column that I have removed from it housing....sorry I dont have a pic of both complete columns side by side.
http://i379.photobucket.com/albums/o...36935047_n.jpg
Showing length of both...
Ignition fitted...
http://i379.photobucket.com/albums/o...30944387_n.jpg
Welded 2 ends of columns together....
http://i379.photobucket.com/albums/o...93188857_n.jpg
Brackets welded on.....
http://i379.photobucket.com/albums/o...14588281_n.jpg
Getting there..
http://i379.photobucket.com/albums/o...81038921_n.jpg
Almost done...
http://i379.photobucket.com/albums/o...58139903_n.jpg
The Following User Says Thank You to bigash For This Useful Post:
GalwayBogger (05-31-2013)
Old 05-14-2012, 04:00 PM   #13 (permalink)
Function over form!
vrmilionzx's Avatar
S14 - '95 Nissan 240sx se
Sports Cars
90 day: 19.89 mpg (US)
S13 - '93 Nissan 240sx base
Sports Cars
90 day: 25.42 mpg (US)
Send a message via AIM to vrmilionzx
I've got an MR2 pump in there, wired to a switch. I didn't get the brain box, so those wires (the clip) are just hanging out in case I want to add it later.
The only time it's even remotely difficult to steer is when I'm at a stop, or very very low speed. The car seems to benefit most from this at highway speeds in terms of mileage, though I didn't do any solid testing to be sure.
What's neat about the MR2 pump is that there is a manual pressure adjustment on the pump, so you can mess with it to find "just enough" assistance when you're not moving.
I haven't yet had any "OH SH**!" moments in which I've needed to turn faster than I am capable. Although it HAS had the added benefit of strengthening my arms a little (I don't actually turn it on very much, only in very tight parking situations).
Old 02-15-2013, 07:47 PM   #14 (permalink)
Champagne - '13 Chevy Cruze 1LT
90 day: 33.35 mpg (US)
Would a good idea be to use the pulley off an a/c compressor with the electric clutch and just turn the pump on when needing to turn? Thought about it for a while but never actually tried it.
Old 02-15-2013, 11:31 PM   #15 (permalink)
Function over form!
vrmilionzx's Avatar
Sports Cars
Sports Cars
That could work - it just sounds like it might be more complicated than getting an electric ps pump wired in. Unless you have the materials on hand, in which case, go for it! I'd love to see how well that works!
dc motor s10 chevy ge, dc pump, power steering
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 7381 08-02-2023 10:55 PM
"underdrive" power steering pump? gascort EcoModding Central 11 03-04-2017 07:44 AM
Power Steering delete for fuel economy gain - anyone done it? bennelson EcoModding Central 92 01-27-2017 03:58 PM
Converting power steering to electric power steering Daox EcoModding Central 54 01-17-2017 06:16 PM
Electric Power Steering w/o hydraulics sirus20x6 EcoModding Central 22 03-07-2011 10:00 AM
