Old 05-04-2022, 11:37 PM   #11 (permalink)
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
Originally Posted by XCRN View Post
I am looking at ways to remove load on the engine of my Jeep while retaining function. I think a good start is going with an electric pump which can be made to work easily. However I want to refine it since most retrofit installs have the pump either off or running 100% which I think will add the load back to the alternator negating gains. I want to be able to vary the amount of voltage based on speeds since I will only need it 90-100% below 25mph and can lower the voltage as speed incrases so cruiseing at highway speeds, the pump will not create load on the motor.
What are options where I can program a PWM output based on a VSS input? I was thinking of using a variable voltage fan controller from a Grand Caravan to regulate voltage to the pump, but I need something to tell it how much voltage to send.
go to a junk yard and pull one from a newer model
Old 05-08-2022, 12:07 AM   #12 (permalink)
A normal power steering pump uses 4 amps or so under no load.
There's no point making your own controller when there's well-tested OEM solutions. Find a pump off some other car, figure out which wires to jump or feed a fake signal to so that it works. The internal logic is good enough to handle "slow pump down when no pressure", no need for connection to the body controller.
Old 05-19-2022, 10:45 PM   #13 (permalink)
You could take a look at the Nissan Versa electric Steering column. They’re cheap on ebay and supposed to work in a default mode.
https://openinverter.org/forum/viewt...t=Versa#p24684
