Old 06-13-2016, 01:22 AM   #41 (permalink)
Originally Posted by t vago View Post
I can also say that when I put a 25% UDP on my Dakota's engine back in 2011, I did not notice any real difference in fuel economy.
Then again, I did not (and do not) really rev the engine that much past 2000 RPM for any real length of time.
Well yea, if your engine has a smaller rev range then a mechanical pump is naturally going to be more efficient. Smaller engines that rev 2500-3000 on the freeway have water pumps sucking down much more power.
Old 06-13-2016, 08:14 PM   #42 (permalink)
Intermediate EcoDriver
Mustang Dave's Avatar
Trigger - '07 Ford Mustang V6 Premium Coupe
Team Mustang
Sports Cars
90 day: 32.76 mpg (US)
Big Red (retired) - '89 Ford F-250 4wd Custom
90 day: 18.13 mpg (US)
Big Red II - '13 Ford F-150 FX4
Pickups
90 day: 19.61 mpg (US)
I installed a 25% UDP on my Mustang's 4.0 liter Cologne V-6 last May. I rarely rev that engine over 2000 RPM, except while accelerating. That mod gave me about 1 MPG. YMMV.
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy View Post
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh View Post
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
The Following User Says Thank You to Mustang Dave For This Useful Post:
ChazInMT (07-21-2016)
Old 07-21-2016, 02:51 PM   #43 (permalink)
I helped with a race car for a couple years that we converted to battery fired and dropped the alternator to save weight and power. The car was a S2000 (Scca road racing) and uses a 2.0 ford motor (Old pinto engine...) Changes were made carefully and logged on the car because the class is so restricted on engine mods. Its all about ounces, aero and ingenuity...
The electric pump did a few things, first it allowed us to run the engine head temp exactly at the highest power yield, it allowed us to ditch almost 30 lbs (Alternator, shorter belt, water pump, and changed the plumbing to a much more efficient layout which helped aero. ) The pump we used was from another vendor but looked exactly like the davies ewp115.
The water pump conversion gave us about 1/2 second a lap. HUGE in this class.. We also ran a very small OddeseyBattery that we had a quick change for so we kept 2 on the charger and one in the car.
Getting rid of spinning weight on the engine for us was a big deal for extracting the most power, which should translate to lower fuel consumption... So we could run less weight in the tank..
If it has a motor its worth playing with.......
The Following User Says Thank You to dwtaylorpdx For This Useful Post:
Old 07-21-2016, 03:45 PM   #44 (permalink)
Prius have an electric water pump, as they do electric air con
They have no accessory drive belt so it has to be
check it out
The Following 3 Users Say Thank You to sidecar For This Useful Post:
ChazInMT (07-21-2016), gone-ot (07-21-2016), niky (07-22-2016)
Old 07-21-2016, 07:10 PM   #45 (permalink)
Originally Posted by Sunaj View Post
I assume one of the kits on his website.. just came across this one..
Electric Water Pump EWP80
I use one on my V6 4.3 chevy trike. Also use their controller. I luv it I plumbed it all in 1 inch heater hose . I also used one to cool a 555 ci supercharged motor for my drag car. they are awesome
