Old 10-10-2008, 10:01 AM   #11 (permalink)
lyd
It smells funny in here.
GeeOh - '97 Geo Metro Base
90 day: 33.41 mpg (US)
I can't comment usefully on the above, but there seems to be a number of links to information and code in this thread on gassavers.org: OBDII CarPC MPG Calculator - GasSavers.org - Helping You Save at the Pump
Old 10-10-2008, 10:32 AM   #12 (permalink)
lyd
DOH! I just noticed that thread is all about you! Sorry. ;-)
Old 10-10-2008, 10:56 AM   #13 (permalink)
01 Insight - '01 Honda Insight DX
90 day: 67.82 mpg (US)
Do you know if your version will work with the ELM327 1.3 chip? I just sent my scantool in for an update (was free aside from shipping) they threw in a new chip and upped the data rate to 38000bps.
I might get a chance to test is this weekend. though I think they released the 1.14 to be compatible with it, even that one didn't work.
also some thing I noticed in the OBD2007 pdf that was posted:
Late model vehicles which use Oxygen sensors known as wide range linear Oxygen sensors, can also introduce another Pid 0x44, Commanded Equivalence Ratio. This pid allows fine adjustment of air fuel ratio from the constant 14.64 by modifying the air fuel ratio by a value between 0 and 1.999 which permits air fuel ratios to be measured to greater precision. If a vehicle supports Pid 0x44, OBD 2007 fuel consumption figure is modified by the effect of Commanded Equivalence Ratio.
Old 10-10-2008, 02:30 PM   #14 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
mtgeekman -
I am 85% sure that mine is based on the 1.14 version. If you can't get that version to "talk" to your ELM327, you'd probably have the same problem with mine.
Originally, I had lots of problems making it work. I found out that I needed a "vanilla clean" XP OS install to make it work. It didn't work with my XP off the bat because it was encrusted with all sorts of "barnacle-programs" that interfered with the COM1 port connection. Here's an experiment to emulate a "vanilla clean" OS that might work for you :
1 - Assuming you have Windows XP
2 - Assuming you are using COM1 or COM# port connection.
3 - Assuming COM# ports work in Safe Mode.
4 - Boot into Safe Mode
5 - Run Scantool 1.14 and see if it works.
I am also assuming that the Alegro SW graphics package won't get too upset with Safe Mode.
I will also try this experiment this weekend if I have the time (messy weekend coming up to say the least).
EDIT: No comment on the wide range linear oxygen sensor because I am narrow band. This may be a BIG help to wide band owners. Good catch!!!
CarloSW2
American Solar Energy Society
Old 10-16-2008, 11:44 AM   #15 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Convert MAP to MAF?
Hello -
(edited multiple times to get info correct)
I have a question. If you know the following about your car :
1 - Engine displacement in Liters. For example, my engine is 1.9 liters (1901 cc).
2 - Manifold Absolute Pressure (MAP) in inHg (inches Mercury). For example, the value that my engine returns in the OBD II protocol.
3 - Compression Ratio (Optional?) . For example, my car has a compression ratio of 9.5:1.
Question : Can you *calculate* the Manifold Absolute Flow (MAF) in grams per second?
Reason : I ask because I am trying to emulate the published OBD 2007 algorithm
Thank You,
CarloSW2
Old 10-16-2008, 04:57 PM   #16 (permalink)
lyd
Do you have a link to that alg, Carlo? I was looking for it the other day and couldn't track it down.
Old 10-16-2008, 05:39 PM   #17 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
lyd -
The "alg"(orithm?) is from post #10 above :
OBD 2007 - Installation Guide
http://www.glmsoftware.com/Documenta...de20080822.pdf - Page 15 of PDF
fuel consumption can be calculated, if a vehicle supports Pid 0x0D Vehicle Speed and Pid 0x10 Mass Air Flow. All vehicles support vehicle speed and nearly all vehicles support MAF.
MAF, the mass of air moving into the engine is measured in grams per second. A petrol/gasoline engine burns the air/fuel mixture at the stoichiometric air fuel ratio of 14.64:1. The oxygen sensors in a modern vehicle are designed in conjunction with both the short and long term fuel trims to maintain this ratio. Under ideal conditions for every 14.64 grams of air an engine will consume 1 gram of petrol. We can therefore calculate FuelFlowGramsPersSec = MAF/Air Fuel ratio. We can convert the previous figure to FuelFlowLitresPerSecond by dividing FuelFlowGramsPerSec by the density of petrol/gasoline.
We can then readily convert that figure to FuelFlowLitresPerHour -- i.e. litres/hour. Fuel consumption is then simply SpeedKmsPerHour/FuelFlowLitresPerHours -- i.e. litres/kms.
CarloSW2
Old 10-16-2008, 08:06 PM   #18 (permalink)
lyd
Oooohh. Right, sorry. ;-) I misunderstood what you were referring to there.
Old 07-25-2010, 05:00 PM   #19 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Hello -
I was toodling around the scantool website and looking at their "OBDWIZ" MPG feature. Look at it's configuration inputs :
ScanTool.net LLC - OBDwiz Automotive Diagnostic Software
It looks like they have three "Fuel Calculation Method" algorithms. Is the "Volumetric Efficiency" of one's engine easy to find?
The above led me to some other interesting (to me) places :
METHOD FOR ON-LINE ADAPTATION OF ENGINE VOLUMETRIC EFFICIENCY USING A MASS AIR FLOW SENSOR - Patent application
Calculating MPG from VSS and MAF from OBD2 - Page 4 - MP3Car.com
http://www.mympgtracker.com/
CarloSW2
Old 08-08-2010, 09:24 PM   #20 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Hello -
Ok, I now have a workable formula, thanks to post #9 :
Calculating MPG from VSS and MAF from OBD2 - MP3Car.com
... For the record, the first "one-line" MPG formula above, taken from my Circuit Cellar article, is off by 100! The "4.54" should in fact be "454". The correct formula is:
MPG = (14.7 * 6.17 * 454 * VSS * 0.621371) / (3600 * MAF / 100)
MPG = 710.7 * VSS / MAF
Note that OBD-II VSS reading is in kilometers/hour and MAF reading is grams/sec times 100.
This formula works very well in a modern automobile because the engine computer spends almost 100% of its time managing the fuel-air-ratio to 14.7, which it can do very well because of the "closed loop" feedback from the O2 sensor(s).
In fact, the accuracy of this method has been proven in literally tens of thousands of gasoline-powered vehicles. Accuracy within a few percent is typical, often limited by the accuracy of the vehicle speed reading (i.e., VSS).
As for other ways of doing this, especially if you don't have a MAF sensor, by knowing the displacement of the engine, and after a simple "calibration" using fuel tank "fill-up" data to find the only unknown, namely the "volumetric efficiency" (VE) of the engine, MAF can be calculated from RPM, MAP and IAT. With VE, one can use the following formulas to calculate a synthetic "mass air-flow" (MAF) in grams per second, all without a MAF sensor, using the "Ideal Gas Law", as follows:
IMAP = RPM * MAP / IAT
MAF = (IMAP/120)*(VE/100)*(ED)*(MM)/(R)
where manifold absolute pressure (MAP) is in kPa, intake air temp (IAT) is in degrees Kelvin, R is 8.314 J/°K/mole and the average molecular mass of air (MM) is 28.97 g/mole. Note that, in the above formula, the volumetric efficiency of the (4-cycle!) engine is measured in percent and the engine displacement (ED) is in liters.
The VE of my 1999 7.4L Chevy Suburban is about 65%. Smaller, higher performance engines can have VE's of 85% or higher.
That led me to this code :
Code:
// For signalling when one of the critical input variables has been received from the ECU/PCM
typedef struct
    // 32 bits
    int    mph:1;
    int    map:1;
    int    iat:1;
    int    rpm:1;
    int   _PADDING:28;
} accessbits32;
// MPGData is global data structure for calculating MPG
typedef struct
    union
        int          accessbit32:32;
        accessbits32 accessed;
    double speed_kmh;
    double speed_mph;
    double map_inHg;
    double map_kPa;
    double rpm;
    double iat_c;
    double mpg_instant;
    double fuel_instant;
    double miles_instant;
    int    mpg_count;
    double mpg_avg;
    double imap;
    double maf_gs;
    double total_miles_travelled;
    double total_fuel_consumed;
} MPGData;
MPGData m;
// Drivetrain specific variables that can be loaded from a file
typedef struct
    double ed;             // Engine Displacement
    double ve;             // Volumetric Efficiency
    double odo_correction; // odometer correction
} DriveTrain;
DriveTrain dt;
// calc_mpg_formula
int calc_mpg_formula()
    int ret;
    double iat_k;
    int kmh_zero;
    iat_k = m.iat_c + 273.15;
    if ( iat_k == 0.0)
        iat_k = ALMOST_ZERO;
    // IMAP =  RPM   * MAP:kPa    / IAT:K
    m.imap  = (m.rpm * m.map_kPa) / iat_k;
    // MAF = (IMAP/120)*(VE/100)*(ED)*(MM)/(R)
    // MAF   = ((   IMAP / 120  )*(VE:% /100)*(ED:liters)*(MM)   )/(R)
    m.maf_gs = (( m.imap / 120.0)*(dt.ve/100)*(dt.ed)    *(28.97))/(8.314);
    if ( m.maf_gs == 0.0)
        // then protect against divide by zero later on
        m.maf_gs = ALMOST_ZERO;
    // where manifold absolute pressure (MAP) is in kPa,
    // intake air temp (IAT) is in degrees Kelvin,
    // R is 8.314 J/°K/mole and
    // MM is the average molecular mass of air (MM) = 28.97 g/mole.
    // Note that, in the above formula, the volumetric
    // efficiency of the (4-cycle!) engine is measured in
    // percent and the engine displacement (ED) is in liters.
    if ( m.speed_kmh == 0.0)
    { // Not a good solution for 0 MPH, but lets give it a try
        m.speed_kmh = 0.161 / 1000.0;
        m.speed_mph = 0.10  / 1000.0;
        kmh_zero = 1;
    else
        kmh_zero = 0;
    // miles travelled in 1 second
    m.miles_instant = m.speed_mph / 3600.0;
    if (( m.rpm < 100) && (kmh_zero == 1))
    { // then EOC
        m.mpg_instant = 9999.0;
        m.fuel_instant = 0.0;
    else
        // MPG - miles per gallon
        // 14.7 grams of air to 1 gram of gasoline - ideal air/fuel ratio
        // 6.17 pounds per gallon - density of gasoline
        // 454 grams per pound - conversion
        // VSS - vehicle speed in kilometers per hour
        // 0.621371 miles per hour/kilometers per hour - conversion
        // 3600 seconds per hour - conversion
        // MAF - mass air flow rate in 100 grams per second
        // 100 - to correct MAF to give grams per second => NOT NEEDED
        //MPG = (14.7*6.17*454*KPH*0.621371)/((3600*MAF)/100)
        //            => 710.7335739 * KPH          / MAF
        //            => 7.107335739 * KPH          / MAF_gs
        m.mpg_instant = (7.107335739 * m.speed_kmh) / m.maf_gs;
        // GPH / 3600 = GPSecond = ( MPH         / MPG          ) / 3600.0
        m.fuel_instant    = ( m.speed_mph / m.mpg_instant) / 3600.0;
    m.mpg_count++;
    m.total_miles_travelled += m.miles_instant;
    m.total_fuel_consumed   += m.fuel_instant;
    if ( m.total_fuel_consumed != 0.0)
        m.mpg_avg = m.total_miles_travelled / m.total_fuel_consumed;
    else
        m.mpg_avg = 0.0;
    ret = m.accessbit32;
    m.accessbit32 = 0;
    return (ret);
} // END calc_mpg_formula()
There are lots of limitations to what I am calculating. I need to get IAT, MAP, MPH, and RPM in one second in order to be able to datalog. This sounds like plenty of time for a computer, but my standing theory is that the ECU/PCM communicates in it's own good time.
Also, I don't know the Volumetric Efficiency (VE) of my engine. This doesn't address the knowledge that VE changes under different loads.
However, I *am* datalogging MPG numbers that are very very very similar to what a Scangauge displays. This has always been my goal, to have a formula that can give me the same *relative* MPG changes as the ScanGauge.
Me Happy, .
CarloSW2
