Old 06-10-2008, 09:21 PM   #1 (permalink)
Car winter button -- slow acceleration
Hi folks,
My Volvo has a winter button, which starts out slowly from stops, despite how much you press on the gas. However, it's sounds like the engine is working harder, despite the RPM being less than 2000.
Has anybody ever checked to see if this helps gas consumption? Just curious....
TIA
Mike
Old 06-10-2008, 09:29 PM   #2 (permalink)
I highly doubt it, its likely their version of traction control and braking or retarding the timing to reduce power to match traction.
Old 06-10-2008, 10:59 PM   #3 (permalink)
Veggiedynamics
Volt12 - '12 Chevy Volt base
many older "winter" buttons simply start the transmission in 2nd.. My old trooper had a winter button that did this.. god i miss that truck.. i still see it every day .. sold it to a coworker.. never should have sold it.. anyway
if thats the cars it could give better milage but that means its slipping alot more when you start off..
Old 06-11-2008, 12:02 PM   #4 (permalink)
Harebrained Idea Skeptic
The White Car - '84 Mercedes-Benz 300td
90 day: 28.84 mpg (US)
The Blue Car - '86 BMW 535i
Last 3: 23.86 mpg (US)
The mid- to late-'80s BMWs with the 4HP22EH tranny (4-speed auto) had an "S*E*3-2-1" switch on the console. "S" for "Sport" had higher shift points, "E" for "Economy" had lower shift points (and was always kicked to that position by a solenoid upon start), and "3-2-1" allowed you to start out and stay in whichever of those three gears you selected.
Old 06-11-2008, 12:40 PM   #5 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
I agree, typically traction control is tied to the ABS and thats just what it sounds like here. If it sounds like its working harder then it probably is, and since the rpms are the same, the brakes must be being applied to hold the car back.
Winter daily driver, parked most days right now
Summer daily driver
Old 06-11-2008, 12:48 PM   #6 (permalink)
Pushrod - '02 Chevrolet Cavalier
The winter button is probably similar to the traction control button on my other Chevy. It selectively skips over cylinders in the firing order if the wheel starts to slip. The reason your car sounds like it's working harder is probably because the throttle is opening wider and making more noise, though not necessarily burning more fuel. This will make your scangauge's fuel consumption read artificially high.
Old 06-11-2008, 03:10 PM   #7 (permalink)
pontiac trans am - '00 pontiac firebird trans am
jeep 1 - '02 jeep wrangler
90 day: 16.76 mpg (US)
jeep 2 - '07 jeep wrangler x
90 day: 19.39 mpg (US)
Toyota - '09 Toyota Corolla lx
that sounds great, i wish all autos had that setup.
Old 06-13-2008, 03:31 PM   #8 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
I tried this on a few rental Volvos: S40, S60 (2005-2008). I think it starts it in 2nd gear, as mentioned -- but (if equipped) the electronic throttle is muted -- so if you mash the pedal, it gradually accelerates. Shifts are softer as well, so it doesn't break loose during gear engagement on slick surfaces.
I used it for a bit and determined that it just wasted fuel between shifts. I would start in normal mode, press the "W" button, and let it be a bit more gradual in how it operated. IIRC, it shifts sooner so you could be fighting the torque converter and get that "working hard" feeling.
I have no official data -- I would recommend to do a test, A-B-A style and record mileage on each run. You would have to reset the car's MPG each time or use a scangauge if you have one -- that sort of thing. Try to maintain consistent pedal pressure on acceleration, maintain the same cruise speed, brake in the same spot, etc. Figure a small route with little traffic if possible and run the same direction.
Best FE to ya...
-RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 06-15-2008, 05:54 PM   #9 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
I used to be a Volvo tech for about 3 years. Winter mode actually starts you out in 3rd gear believe it or not.
GeoMetroforum.com - got mpg?
Old 06-16-2008, 02:08 AM   #10 (permalink)
Depends on the Day
RH77's Avatar
Sports Cars
3rd -- wow! That makes sense with the "bogged-down" feeling. The first time I drove one in W mode, it really struck me as an odd-accelerating vehicle.
Does it do all that other stuff too? (it was mostly a guess/observation on my part).
RH77
_
_
DIY: Push Button Start SVOboy DIY / How-to 20 07-10-2014 09:43 AM
I found another advantage to driving an ultra-low Cd car basjoos Aerodynamics 26 08-25-2012 02:15 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
My First Electric car Experience WaxyChicken The Lounge 8 09-05-2008 08:46 PM
