Old 10-18-2015, 03:21 PM   #1 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 37.93 mpg (US)
Energy from throttling losses
We all know that a lot of energy is wasted by the throttle valve in a gasoline engine. We also know that diesel engines are more efficient because they do not have throttle valves. And we know that air flows through the throttle valve.
Somebody had the idea to make use of the lost energy by replacing the throttle valve with a turbine connected to a generator, and controlling the generator load through the gas pedal to control the air flow to the engine. See patent #5,394,848 for the details. Go to Google to see the patent.
At the bottom of the page is a list of 23 other patents that build on this patent. This patent is expired, so anybody can build, use, or sell anything in it.
The only real problem is the range of pressure drops and flow rates make it impractical to completely replace the throttle valve with a turbine. Other than that, the basic concept is valid.
The Following 2 Users Say Thank You to JRMichler For This Useful Post:
pgfpro (10-18-2015), redpoint5 (10-19-2015)
Old 10-18-2015, 03:58 PM   #2 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Very Interesting.
Pressure Gradient Force
The Positive Side of the Number Line
Old 10-18-2015, 05:55 PM   #3 (permalink)
The link takes me to a blank Google patent search page, but seems to work for others.
Does it use a variable pitch turbine?
Old 10-18-2015, 07:53 PM   #4 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Same here so I just out the pat # in google search and it came up.
Old 10-18-2015, 08:30 PM   #5 (permalink)
The energy is not wasted primarily by the act of restricting the throttle itself, which takes very little energy to actually restrict. The loss created by the restriction is primarily due to the reduction in the pressure of the air, thus the mass of that same air, entering the engine itself.
Similarly the act of restricting the flow of water in the hydroelectric plant, while not terribly energy costly, has a much larger consequence, in power generated, versus restrictive energy requirement.
Think vacuum windshield wipers.
regards
mech
Xist (10-20-2015)
Old 10-18-2015, 10:52 PM   #6 (permalink)
Dark Egg - '12 VW Touraeg
What if you had a massive EGR that could send all of the exhaust back through the combustion and the throttle was actually on the EGR. Opening the throttle would reduce power and maximum power would come when the EGR "throttle" was closed.
The Following User Says Thank You to Hersbird For This Useful Post:
Old 10-18-2015, 11:45 PM   #7 (permalink)
What if you had a massive EGR that could send all of the exhaust back through the combustion...
Then you wouldn't have combustion, since almost all the oxygen would have been used the first time through :-)
Old 10-19-2015, 12:42 AM   #8 (permalink)
All but a tiny bit, just enough to idle. Then less and less the more power you wanted to make. Sort of opposite how a normal throttle works. But if it were not in the intake side it wouldn't be wasting energy making vacuum, or much exhaust for that matter at light loads. Basically let 90% EGR turn a 2000 cc motor into a 200cc motor until it needs it. I assume this much EGR has been tried and combustion fails at some point at least when applied to current conventional bore, stroke, valves, compression, etc.
Old 10-19-2015, 05:55 AM   #9 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 144.39 mpg (US)
Send a message via MSN to jakobnev
http://ecomodder.com/forum/showthrea...tem-19845.html
Every one invents that.
Old 10-19-2015, 06:36 AM   #10 (permalink)
90 day: 29.78 mpg (US)
Isn't the Atkinson cycle supposed to alleviate some of the throttling losses?
