Old 07-26-2016, 08:20 PM   #11 (permalink)
File fit oil rings, with a real narrow gap. 14 to 18 thousands top and a little wider 2nd gap.
Raise the compression ratio.
Put a block heater on the engine.
Reduced oil ring tension.
http://ecomodder.com/forum/showthrea...ger-29085.html
Old 07-27-2016, 12:06 AM   #12 (permalink)
Semi-serious ecomodder
ChillyBear's Avatar
I think you question deserves an answer:
  • Blueprinted for clearances and balance.
  • Wear surfaces cryogenically tempered prior to machining.
  • Exterior surface with heat-rejecting aerospace coatings.
  • Combustion chamber surfaces (head, cylinder valve heads.) coated with ceramic heat-proof coatings.
  • Piston skirts, rings and bearings with low-friction aerospace coatings.
  • Anti-reversionary headers and everything everyone else has suggested.
You can price that all out, calculate the ROI and have a sad.
ROI=sad.
