Old 12-05-2022, 03:53 PM   #91 (permalink)
Righteous Imaginarian
Talos Woten's Avatar
Champrius v3.2 - '09 Toyota Prius
90 day: 58.73 mpg (US)
Thumbs up Effectiveness vs Efficiency
Originally Posted by Phase View Post
Know any ways to get hot air to blow in the cabin faster? I don’t even care that much about mpg in winter. I just wanna be warm lol
Hmmm... if *that's* your main concern, perhaps you'd be better off investing in a car seat heater and/or 12V electric blanket. Or you could really splurge and get a new driver's seat with heat/AC. I almost got one for myself for the AC... until I found a great bead seat cover that massages and has good airflow. My posture (and temperature) are much improved.
Currently building Champrius 4.0! Follow starting here:
https://www.instagram.com/p/CeeL6xyFp-k/
and ask in depth questions here:
https://ecomodder.com/forum/showthre...tml#post669277
The goal is 70 mpg this time around.
Stats from Champrius v3.2:
The Following User Says Thank You to Talos Woten For This Useful Post:
hayden55 (12-05-2022)
Old 12-05-2022, 06:02 PM   #92 (permalink)
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
i have a car seat heater. wish i could do a heated steering wheel too but after market ones dont work apparently
wouldnt the insulation help? warm engine means hot air?
Old 12-05-2022, 06:56 PM   #93 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
Sequoia - '04 Toyota Sequoia Limited
90 day: 17.51 mpg (US)
that's what i'm thinking about at this point. $100 and time for the steering wheel heater and cover, wired into the clock spring. Seat heater from the junkyard can be had for free but requires lots of time for install lol.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 12-05-2022, 07:16 PM   #94 (permalink)
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
From an energy stand point it's a lot more effective to heat your body directly. A heated seat uses about 50W. But of course the heat generated by your burning gasoline is basically wasted heat anyway.
Old 12-05-2022, 08:13 PM   #95 (permalink)
Two days ago on Youtube:
I could retrofit my old letterman's jacket.
The best accident is no accident -- Elon Musk
Old 12-06-2022, 09:30 PM   #96 (permalink)
Phase's Avatar
20 minutes of city driving and I can’t even get the temp to budge. I can get it to go up one or two bars if I rev it in sport mode. Def need some insulation or other hacks…
Old 12-07-2022, 10:36 AM   #97 (permalink)
Those dummy gauges are horrendously inaccurate. If it doesn't read in single degrees just ignore it.
The Following 2 Users Say Thank You to hayden55 For This Useful Post:
Isaac Zachary (12-07-2022), Piwoslaw (12-08-2022)
Old 12-07-2022, 10:45 AM   #98 (permalink)
I have both the dash gauge and a Scangauge in degrees on the Avalon. The dash gauge moves to the middle at around 130 or 140°F and stays there up past 200°. I don't know how much as I haven't ever gone much above 200°F.
So from the far left it starts moving at 100°F and 30° or 40° later it's in the middle and then stays in the middle for at least the next 60° or 70°.
Old 12-07-2022, 10:57 AM   #99 (permalink)
lol lucky. On most of my vehicles they stay in the same spot lol
Old 12-07-2022, 11:52 AM   #100 (permalink)
Phase's Avatar
Well having it at the middle is the peak fuel economy area right? Because I’m getting horrible city mpg… not to mention I lose heat pretty fast when my car switches to ev mode
