Old 04-07-2010, 02:48 PM   #11 (permalink)
Hyperlurker
daring4's Avatar
D-max - '04 Chevy Silverado Ls
Notch - '65 Volkswagen 1500 S
MTCHBX - '05 Scion XB
90 day: 40.41 mpg (US)
Wow thats a lot of miles without a rebuild! I do know how cooling systems function, been a car guy for 21 years, I was thinking about the oil when the engine is at 230. Its clear that your car is mantained well to last that long. Good job!
I'm not sure about humidity, I look at it this way, wind chill only affects objects that lose water through a membrane(skin). Buildings and cars don't see wind chill, so high humidity and hot air sucks for us but maybe not for cars...or my head could be up my a$$ again!
The grill block is held on with white duct tape(white car) so I can pull over and take it off if it gets too hot
Bad news today, your tank mileage goes in the crapper if you need to replace all of your control arm bushings! Driving it up onto the ramps to get a jack under the front end(car is too low) eats away at some of the gains I made. I was at 33.2 now its 31.5
Perfecting Going EOC After Dark Jammer Hypermiling / EcoDriver's Ed 20 09-30-2009 09:27 PM
EOC and bad mpg... 97Cavalier Hypermiling / EcoDriver's Ed 10 05-05-2009 09:23 AM
Best MPG with EOC & without EOC xbUser Hypermiling / EcoDriver's Ed 21 08-22-2008 12:25 AM
EOC fuel usage ?'s reformed EcoModding Central 4 06-12-2008 09:51 PM
EOC Question - what did i do wrong? Doofus McFancypants Hypermiling / EcoDriver's Ed 12 02-15-2008 02:18 PM
