Old 08-03-2008, 02:43 AM   #1 (permalink)
TrikeKid's Avatar
The ClownCar - '91 Geo Metro Base
Send a message via AIM to TrikeKid Send a message via Yahoo to TrikeKid
P&G and U-Joints in RWD rigs?
I did a couple p&g's on my way home where it was feasible to do so tonight. Both were pretty smooth, but I noticed my driveline vibes a little more than normal when I got back onto the highway. It has always vibrated, combination of worn t-case and a questionable u-joint. I've got a new trans and case ready to go into the truck, so I'm going to put new joints in both ends of the drive shaft when I install that (wasn't going to put new joints in at $20 a piece to have the sloppy case output beat them to death). I'm wondering if anyone here that's P&G'd in a RWD/4WD vehicle has noticed increased wear on the joints? There are a number of places here where a P&G wouldn't even really slow you down if you time the hills right so I'd like to get into it a little more.
Old 08-03-2008, 03:10 AM   #2 (permalink)
Red
Red's Avatar
If your u-joints are in good shape it shouldn't matter. All you are doing is accelerating/decelerating. Provided that there isn't any excessive slop in the drive train, it should be fine.
Old 08-03-2008, 07:44 PM   #3 (permalink)
TrikeKid's Avatar
That's kinda what I figured, thanks.
Old 08-04-2008, 12:16 PM   #4 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Id think typical city drivers are worse on a driveshaft than you doing P&G.
Winter daily driver, parked most days right now
Summer daily driver
Old 08-13-2008, 01:50 AM   #5 (permalink)
TrikeKid's Avatar
I was worried about the bump starting mostly, most of the time I'm pretty smooth about it, but every once in a while it'll jump pretty hard.
Old 08-13-2008, 02:42 AM   #6 (permalink)
Red
Red's Avatar
Yeah shock loading is bad....
Depending on your hardware, might not hurt a thing, but its not the path to long part life either
