06-17-2013, 07:13 PM
#11 (permalink)
TheEgg - '18 Volkswagen Tiguan SEL Premium 90 day: 29.55 mpg (US)
I was giving actual numbers reported by my SGII...12 and 16 horsepower at 60 and 80 mph respectively, which fit a similar curve to the Prius on the chart.
Maybe I'm missing something, but I think most of the horsepower used at 60 mph is just keeping the engine up to speed, with only a few additional needed to overcome rolling resistance and aerodynamic drag at that point, so you're starting with maybe 3 or 4 horsepower in the equation, not 12.
05-06-2020, 11:39 PM
#12 (permalink)
Engineering first
Recently I tried to measure the roll-down coefficients and found they are impractical for my studies. But I did find a 'good enough' approach using three benchmark points and better still, four points.
EPA ROLL DOWN PROTOCOL (SAE J1263)
The EPA publishes the roll-down coefficients for: - A (lbs/velocity**2) - corresponds to aerodynamic force
- B (lbs/velocity) - corresponds to rolling drag
- C (lbs) - corresponds to vehicle overhead
So following the protocol of SAE J1263, I tried to locally replicate but was disappointed. The full protocol requires 16 bi-directional passes on a sufficiently flat track. Using the closest road to the airport:
For my first tests, I used "Scan My Tesla" and "Speedometer" GPS records:
- There were problems getting the same section of the test track. I'll have to re-run to identify the specific start and stop spots after doing a dash cam plot.
- GPS data is notorious for having altitude challenges.
- The South bound runs were consistent because I'd mapped the starting position accurately.
- The North bound runs were less consistent so their runs, especially below 40 mph, had significant variance.
- There is no altitude metric in "Scan My Tesla".
I'll have to survey the test track and get a better start positions identified on both the North and South bound routes. I also have a high-resolution, 6-axis accelerometer that can provide altitude changes as well as acceleration and derived velocity. Combining the data is doable but not trivial. Still, I should be able to get credible A, B, and C coefficients.
BENCHMARK SOLVING QUADRATIC
My faster, alternate is three point, benchmarks:
 - Perform at least three different speed, benchmark:
- < 15 mph - Prius benchmarks show the maximum is in the 15-20 mph range. The low value sets the maximum range part of the parabolic curve to real world values.
- > 20 mph - Set the range of the minimum power, curve, which in the Prius is 15-20 mph. We need the minimum power value to evaluate the effect at ordinary speeds.
- 40-45 mph - A middle range speed used for urban travel. Not necessary BUT in this case, accidentally having the heaters on result in a significant increase in Wh/mi.
- 65-75 mph - The high-speed benchmark gives a way to evaluate aerodynamic changes.
- Use a "Three Point Parabola Calculator" or "Three Point Quadratic Calculator"
- Use at least three benchmark points, more helps identify problem (see bad data point)
Unlike roll-down benchmarks, these can be performed in 1-2 hours. Also, the sensitivity of roll-down appears to be poor at slow speeds. Regardless, make sure to use a checklist to avoid problems like my unplanned heater test. Hold as many environmental parameters constant.
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
05-11-2020, 02:53 PM
#13 (permalink)
roll down
Originally Posted by bwilson4web
Hi
Recently we were discussing the HP-to-road power in a thread over at PriusChat. So I posted a recent chart showing the power required for a Volt vs Prius Plug-In (PiP):
One of the posters correctly pointed out that my chart projects ~27 hp at 100 mph. Obviously something is wrong as this is off by a factor of four. Perhaps you' all can spot my error?
I'm using the following:
Now in the past, I've used an OBD scanner to record ICE rpm and MG1 torque to calculate shaft HP. This has been in fine agreement with the specs for our NHW11 (2003 Prius.) So I need to repeat this analysis using the EPA roll down coefficients and compare. But I'm really scratching my head on this one.
Any thoughts?
The reason this is important is the title of the thread,"64% of Prius Power gets to wheels during max acceleration?" The original poster is using some raw acceleration numbers and the vehicle weight to calculate the HP-to-road metric and found only 64% is getting there. This suggests an exceptional transmission efficiency loss.
Understand, I'm OK with this as it may provide more insights about Prius transmission efficiency . . . if we can find independent confirmation. Unfortunately, I did a bad thing . . . loaned out my 2010 Prius OBD scanner. This one can read out ICE rpm and MG1 torque providing the raw HP data at the input to the transmission.
Thanks,
Bob Wilson
I've never heard of a 'roll down' coefficient.Can you expand on that?
05-12-2020, 12:37 AM
#14 (permalink)
Engineering first
It is a sophisticated (i.e., technically challenging) EPA technique that takes a car to at least 70 mph and measures how long it takes to reach 15 mph, SAE J1263: - Standard day temperature, ~60 F.
- Very level, +/- a few feet, straight at least a mile track.
- Wind and other climate limits.
- 16 bi-directional runs.
From the roll-down metrics, you can develop three drag coefficients: - A - lbs per mph squared
- B - lbs per mph
- C - lbs
With these three coefficients, you can plot the drag force as a function of speed or more useful, the drag power needed as a function of speed. Combine that with the drivetrain efficiency, you can make a curve showing the MPG or kWh per mile as a function of speed.
My technique is to use at least three benchmarks to derive the quadratic equation. Two have to be on either side of the local minimum or maximum, and the third out into the high-speed region. Then use a quadratic solver to derive the A, B, and C coefficients. This is much easier and less complicated than the SAE J1263 procedure.
Using this procedure, we can test changes to improve a car's performance, either acceleration and/or range.
Bob Wilson
The Following 2 Users Say Thank You to bwilson4web For This Useful Post:
05-13-2020, 03:49 PM
#15 (permalink)
roll down
- B - lbs per mph
- C - lbs
Bob Wilson
It doesn't sound rigorous enough.The SAE Handbook lists the procedure for coastdown testing.The technical and instrumentation requirements are so rigorous as to be,in my opinion,beyond the reach of individuals like us.
Without the polar moment of inertia for every rotating mass on and in the car,it's impossible to accomplish the data reduction necessary to reveal the coefficients.I've tried it and gave up,ending up paying a qualified 3rd party to test it for a fee at a test facility.$500 in 1991 dollars.
