Old 05-19-2009, 01:34 PM   #1 (permalink)
jeep - '96 jeep grand cherokee limited
90 day: 20.06 mpg (US)
ethanol and carbs?
just a quick thought, but if someone had a carb'ed car and mixed ethanol and gas in the right percentage, could you lean the mixture out to the point just above where fe would go down? i know adjusting the mixture would do the same thing but...
Old 05-20-2009, 01:20 PM   #2 (permalink)
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
Ethanol has less heat potential than gasoline. I believe around 25% less. You can lean the mixture out by adding alchohol, but I don't think your MPG will go up at all. Tuning your carb is a better idea.
Don
Ethanol problems ? Denis DIY / How-to 16 05-31-2011 06:14 PM
