Old 01-02-2009, 04:32 PM   #1 (permalink)
New Year's Resolution: Scratch Building an FE (diesel electric hybrid) car.....
After much thinking, and many drinks, I've decided that current car offerings are unsuitable for super high fuel economy numbers. So, I've decided to jump in and build my own high-mpg car..
Goals are:
1.Capable of freeway speeds
2.Under 5K (this one might be hard)
3.Over 100mpg.
Luckily I have the help on an engineer friend who will help me create an electric-diesel vehicle. For registration purposes (and to drive in the carpool lane) it will be three wheeled, even though I didn't really want it to be. For power I'm starting out with an old-school E-tek electric motor, which provides a constant 30 lb-ft of torque. Not much you say? Well this sucker is going to be LIGHT.
Since I am a dreamer, but no fabricator, I'l be starting out with a t-bucket chassis and front suspension, most likely from Total Performance of some other similar shop. The rear suspension will be a motorcycle swingarm, and the regen for the electric motor will be a 10hp diesel generator which uses about 1 gallon per 5 hours at 12 volts. I've built a T-bucket before, and I can tell you that the chassis, front suspension, and steering only weighs a few hundred pounds.
I'll be running a 24 volt alternator off of a motorhome for a charging system, and I expect the running vehicle to be well under 1000 pounds with a rollcage (don't want to get smashed by LA traffic)....since my Chevette only makes about 70 lb-ft at peak, and weighs 2400 pounds, the vehicle should be plenty fast to "keep up with traffic."
Wish me luck guys and gals, I'll keep updating this thread as I make progress......
For now, here is an example of what I'll be shooting for, minus the hi-po engine but with a much more enclosed bodywork....
http://img442.imageshack.us/img442/4...ympus69ck5.jpg
1989 Dodge Diesel 972rwhp, 27mpg.
1971 Nova tubbed, solid cam 355 w/nitrous, 8mpg (sorry).
1960 Nash DIY Hybrid Project
Old 01-03-2009, 12:17 PM   #2 (permalink)
Fokus - '12 Ford Focus SE
90 day: 32.45 mpg (US)
Lecksus - '03 Lexus RX300
90 day: 17.61 mpg (US)
Benzzzzz - '11 Mercedes Benz ML-350 4-Matic
90 day: 18.75 mpg (US)
you could use a fork lift electric motor
"The Stone Age did not come to an end because we had a lack of stones, and the oil age will not come to an end because we have a lack of oil" ; His Excellency Sheikh Ahmed Zaki Yamani (Saudi Arabia Oil Minister from 1962 to 1986)
https://ecomodder.com/forum/em-fuel-...ehicleid=10608
Old 01-03-2009, 12:34 PM   #3 (permalink)
I like it! Especially the Gatling guns mounted inboard of the front wheels :-)
Old 01-03-2009, 03:58 PM   #4 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Wow - looks like a major challenge to me!
GOOD LUCK with it!!!
Coast long and prosper.
Old 01-03-2009, 06:07 PM   #5 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Originally Posted by JQmile View Post
After much thinking, and many drinks...
Wow, you type well for someone who's had many drinks .
Sounds interesting. Subscribed.
Old 01-03-2009, 06:09 PM   #6 (permalink)
PS - I added "diesel hybrid electric" to the thread title. Hope you don't mind.
Old 01-03-2009, 09:14 PM   #7 (permalink)
I'm a writer by trade so that helps...and spell check can be a good friend for those who type fast and carelessly
Oh, and as I learned from the GM guys, the car will actually be an E-REV (extended range electric vehicle) since only the electric portion of the power system will be driving the wheels. I just figured a diesel engine would be the most efficient generator until something else comes up.
Old 01-03-2009, 09:15 PM   #8 (permalink)
Cause I'm an 80's Baby!!
festivaWES's Avatar
Festiva hauler - '02 Chevorlet S-10
90 day: 27.98 mpg (US)
My resolution is to make my s-10 hit the 35gpm mark.
In search of the ideal gas mizer.....METRO
Diesel- and Hybrid-Powered Vehicles Can Provide More Societal Benefits than Gas-Power SVOboy General Efficiency Discussion 12 04-29-2017 08:03 AM
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
News: VW to unveil 70 mpg (US) Golf diesel hybrid MetroMPG Hybrids 27 06-29-2010 07:50 AM
Diesel electric kit car, anyone? R. Q. Riley's latest takes shape (and looks good!) MetroMPG EcoModding Central 11 10-07-2008 02:52 PM
Hybrid Electric Scion xB trikkonceptz Hybrids 5 06-02-2008 05:14 PM
