Old 08-09-2010, 12:18 PM   #1 (permalink)
90 day: 29.78 mpg (US)
6th gear swap?
I drive a 2006 Acura TSX 6-speed manual, and the car has among the lowest Cd I've seen (.27). When I bought the car, I was thinking that with 6 gears, the top gear would be very tall and good for highway travel. The reality is that it's geared very low and has close ratios. At 70mph, I'm doing 3000RPM, which seems a bit high.
Is it possible to swap out only my 6th gear so that I can accelerate quickly in the first 5 if I wanted to, but shift into 6th to cruise efficiently? If it's possible, how difficult would the job likely be?
At 70mph, what RPM are you running?
Old 08-09-2010, 01:21 PM   #2 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
redpoint5 -
(this is all just guesswork)
Without knowing, I would suspect a gear swap is dependent on what Honda/Acura vehicles use the same tranny. If it's an "Acura-only" tranny, then I doubt that a tall 6th gear exists. Assuming a taller 6th gear does exist, you probably would have to drop the tranny. There is a micro-chance that you could swap the gear without dropping the tranny :
http://ecomodder.com/forum/showthrea...swap-2779.html
I am running around 2460 RPM at 70 MPH.
CarloSW2
American Solar Energy Society
The Following User Says Thank You to cfg83 For This Useful Post:
redpoint5 (08-09-2010)
Old 08-09-2010, 01:47 PM   #3 (permalink)
I run 3500 RPM at 70 MPH. Not good for fuel economy...
-soD
Old 08-09-2010, 02:18 PM   #4 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
2500rpm on three cylinders.
Lately Honda and most other manufacturers have been gearing their cars like yours, so they feel responsive on the highway and you don't have to downshift for ridges and hills. I guess they think folks who buy a brand new stick shifted car are after sportiness, not economy.
Is swapping a gear really that easy? I wouldn't mind having a backwards 2nd gear in place of my 4th. That would give me 2000RPM at 70mph, which would be okay in the winter when I can't lean burn at those speeds anyway.
Old 08-11-2010, 05:59 PM   #5 (permalink)
"Mista Bone" on the Honda boards is regarded as a D-series transmission guru. He tells me that you cannot swap the drive and driven gears to give you "inverted" gear ratios. Which is too bad, because an inverted 2nd gear sounds very attractive for MPG...
-soD
The Following User Says Thank You to some_other_dave For This Useful Post:
cfg83 (08-11-2010)
Old 08-11-2010, 11:32 PM   #6 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Any Idea what transmission is in the TSX?
Good looking cars, friend of mine has a Type S fun.
I'm just under 2000 at 70 mph.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 09-09-2010, 02:28 PM   #7 (permalink)
Ecobalt's Avatar
Get bigger diameter tyres. Ok, I am half way joking.
Old 09-09-2010, 07:21 PM   #8 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
You don't even want to know what RPM I'm turning @ 70MPH.
Front wheel drive is not amenable (as a rule) to gear swaps.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 09-09-2010, 07:26 PM   #9 (permalink)
EV OR DIESEL
In SOME cases FWD gear swaps are easy, first that comes to mind is the 5 speed VW box.
To swap the 5th gear you don't even have to drain the fluid out! Basically jack the car up only on drivers side (sloshes fluid over to passengers side) remove wheel, side cover (6 13mm bolts) and there is the 5th gear set right in front of you.
However in many cases, no so easy . . . .
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
Story of a custom 5th gear for a '98 Ford Escort ZX2: +6% MPG MetroMPG EcoModding Central 14 03-05-2020 06:20 AM
Saturn S-Series 5th Gear Swap cfg83 EcoModding Central 61 05-02-2012 09:31 PM
Geo Metro XFi cam swap How To Johnny Mullet DIY / How-to 13 01-31-2012 09:05 AM
Met an unhappy Aveo owner today MetroMPG General Efficiency Discussion 24 10-10-2010 07:03 AM
Subaru Justy Gear Swap? mtgeekman EcoModding Central 4 08-19-2009 11:33 PM
