04-08-2010, 07:15 AM
#201 (permalink)
plastic, stainless, or aluminum is probably the better route to go. i used the cheap pizza pans from wal-mart and its been about a month since i installed them and they are rusting pretty bad already.
04-08-2010, 08:06 AM
#202 (permalink)
There are aluminum pizza pans -- you want the "coupe" style which have the smooth radius on the edge.
04-15-2010, 12:03 PM
#203 (permalink)
A madman
I've gone the tape route after giving up with pizza pans. My wheels just dont want to accept anything not permanent and I dont want to give up having exposed lug nuts/valve stems.
Used waterproof, paint-able tape so we'll see how it goes. Had to leave one spoke open though for the valve stem. Painted them with plasti-dip so its reversible if it completely goes to crap. But I really like the black wheels with the car now anyway.
Here's a pic of how she looks after a week. Also, snarf says hi.
04-15-2010, 09:32 PM
#204 (permalink)
Bruce,
How had you attached the pizza pans? The tape looks fine. Did you try the upper grill blocked and a partial lower block?
04-16-2010, 01:10 AM
#205 (permalink)
A madman
I can't do a lower grill block, I dont have a lower grill. The car got hit in the parking lot and they wanted too much to fix it, so I just amputated the bumper. Theres not much behind that coroplast really.
As for attachment methods, I tried the center bolt and I tried zip ties. Neither of which really worked well. And both of which I would have had to drill out 6 holes, 1 for the valve stems and 1 each for the lug nuts. It would have been too much work for something that I think would have looked worse. The only question now is how long the tape holds up.
04-20-2010, 10:38 PM
#206 (permalink)
halos.com
I like that! Tape would be pretty easy to install. I might have to try that, if I can find some down here in OKC before we roll out.
04-20-2010, 11:54 PM
#207 (permalink)
24.27 lbs per gallon Co2
Unicorn - '12 Nissan Versa 1.8S hatch 90 day: 31.9 mpg (US)
Brucey, the Lesbaru looks hawt. Mad Max style... efficient and bad ass!
~Jimbo
P.S. Is it just me or are those mirrors HUGE?
Hehehe... If one of your facial lacerations leaves a small scar, you'll have a SCarlett.
04-21-2010, 08:15 AM
#208 (permalink)
I also tried the Wal Mart pizza pans on an Echo. The OEM Echo plastic weel covers make a great mount. The pans just touch the wheel covers at about 3" off center, so a 6" rivet circle of 6 rivets each wheel made a strong mount. The installation was pretty slick. The new wheel covers could be gently pried off, just like the OEM covers. If the Scion covers don't work, you might find a cheap set of covers at Wal Mart which do.
I also shared the rust problem. If you go that route, then paint the outsides, possibly inside also, of the pans before you ever use them.
I like the look of your covers brucey!
04-21-2010, 08:46 AM
#209 (permalink)
Left Lane Ecodriver
You've murdered out your whip, son! (as they say on fashion-oriented automotive customization sites)
The front bumper and wheels provide many of the cues that help people identify that car at a glance as a Subaru. With those gone, I had to look twice.
04-21-2010, 01:52 PM
#210 (permalink)
A madman
Thanks for the compliments guys, the tape seems to be holding up well enough.
I know the tape will eventually fail, but the question is how long is eventually (:
And yes, my mirrors are huge. They look like they belong on a truck. It's nice cause there is no blind spots, its bad because of the obvious gas mileage hit I take with them. When I'm on the interstate I tend to fold the passenger side in, it helps a small bit.
