Old 06-14-2010, 09:36 AM   #221 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
In normal daily driving, I decided to check the brake temperature. I was able to reach around the back and hold onto the brake discs. They were only lightly warm. If you're trying to "drive without brakes", it's not going to be any problem.
For long grades, as Neil said, downshift and engine brake.
Old 06-24-2010, 12:17 AM   #222 (permalink)
XJguy's Avatar
Guys all this search for "moon" covers....they are called Moon because Mooneyes invented them and they are readily available even in custom sizes and in snap on or screw on varieties.
www.mooneyesusa.com/moon-discs-c-188_211.html
Specialty Equipment Manufacturer Mooneyes Online Store - Speed and Custom Parts, Accessories, and More
Old 06-25-2010, 09:01 AM   #223 (permalink)
Hypermiler
Wagons
Try adding an "L" to the end of that link.
Also, we look for alternatives because those are $$$.
Old 06-26-2010, 04:04 AM   #224 (permalink)
Hello, Concrete,
That is encouraging data on the wheel covers! I think I'll try that. My truck currently is getting about 18mpg hwy and I know I can improve it a lot, a little at a time.
Old 06-27-2010, 02:12 PM   #225 (permalink)
XJguy's Avatar
Thanks....left it off because I was under 5 posts couldn't put up links.
The wheel covers are cheap...look again. Under $30 each and look great and fit right.
Old 06-27-2010, 02:19 PM   #226 (permalink)
...beats walking...
...unfortunately, their 16" moons are $50.50 each (not $30-something) and don't have any valve-stem access for checking tire air pressure (not good).
Old 06-27-2010, 05:45 PM   #227 (permalink)
XJguy's Avatar
True...that is a good deal more $$. But as far as a valve stem hole, thats very easily remedied with a hole saw....or better yet install electronic air pressure monitoring that way you don't have to give away any aero advantage.
Old 06-27-2010, 10:24 PM   #228 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
That still is a ton more money. We mostly look for cost-effective solutions.
In Reason we Trust
Old 06-27-2010, 11:35 PM   #229 (permalink)
XJguy's Avatar
Well there is a saying penny wise dollar foolish. Time is money, looking for a perfect solution when one is manufactured to perfection, sometimes its just worth it to buck up....and of course there is aesthetics...but that is just me.
Old 06-28-2010, 09:08 AM   #230 (permalink)
Hypermiler
Wagons
I ended up using a set of nearly smooth plastic hubcaps. They give me 90% of the benefit of moons, and cost $25 for the set.
