Old 03-12-2020, 11:58 AM   #11 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Back in the '80's Hot Rod magazine had a series of articles where they stripped weight from some otherwise stock car, ultimately ending up with no body whatsoever; IIRC just the firewall and dashboard. My cousin did that to some heap he had access to and I'm told nobody, NOBODY could touch him in a drag race.
Are you thinking of the Sport Compact article where they chop up a Sentra until it's a floorpan with wheels? (I had a link to it, but it appears to have died). IIRC, they reduced the 1/4-mile time from something like 17 seconds to 14.
Hot Rod did a Duster drag car with significant weight reduction, replacing body panels with fiberglass, etc. They dropped nearly 600 lbs and included cost per pound lost.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 03-25-2020, 05:08 PM   #12 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
I hear that some of the "stock" cars racing at Goodwood have been "strategically rusted" from inside so that you can put your hand through flawless looking deck lids. For super-light fenders and other panels, you can pull a fiberglass mold from the metal part, and then build up a thin fiberglass skin, with a layer of foam and then another thin skin, and a few extra layers where needed for the bolts, etc.
Old 03-25-2020, 05:54 PM   #13 (permalink)
It's often reported that some Brazilian DKW racing cars had their body replaced with fiberglass ones which were so thin to the point of being translucent.
Old 03-25-2020, 06:07 PM   #14 (permalink)
All fiberglass is translucent unless heavily pigmented.
In the Kinetic Sculpture Races, there was a replica 1960s Cadillac convertible that weighed about 110 lbs - 50 kg. It would churn serenely across the water on its 2" styrofoam chassis pan, with four riders.
Last edited by Bicycle Bob; 03-25-2020 at 06:09 PM.. Reason: Translucence addition
The Following User Says Thank You to Bicycle Bob For This Useful Post:
Xist (03-25-2020)
Old 03-25-2020, 11:57 PM   #15 (permalink)
I forgot it, but even with some pigmentation those were reported to be quite translucent. Well, presumably such a thin layer of fiberglass won't stand to a lot of pigmentation...
Old 03-26-2020, 09:06 AM   #16 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Reminds me of one of the silly project articles Car & Driver did about a million years ago. The premis was that one of the writers ran into someone about to spend $$$ on a Civic to get it to some really low 1/4 time.
They framed the article along the lines of "I said I could make it get that time, spending under $XXX" and the storyline was "look at what we tricked this kid into letting us to to his mom's car".
They mainly went with weight and frontal area reduction. With a sawzall. And recouped most of what they did spend by selling the OE rims and getting steelies from a junkyard.
And ended with "Here- we got that 1/4 time you wanted for dirt cheap, just like you wanted".
Transmission type Efficiency
Old 03-26-2020, 04:03 PM   #17 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
I believe an Insight shell weighs only ~250-300lbs. It's a much better candidate for weight reduction than a Civic.
Just pull the batteries out and replace the glass with plastic and you're probably close to 1000lbs.
Old 03-26-2020, 04:23 PM   #18 (permalink)
Speed holes everywhere.
https://i.kinja-img.com/gawker-media...jzd2eihqoc.jpg
Old 03-26-2020, 06:49 PM   #19 (permalink)
Makes me lurk about the aerodynamic impact of all those holes, and if an approach similar to the golf balls could actually fare better.
freebeard (03-26-2020)
