Old 05-19-2010, 04:56 PM   #1 (permalink)
I have to start over?
Big inefficient truck - '94 Dodge Ram 2500
90 day: 12.1 mpg (US)
Honda Civic - '84 Honda Civic DX Hatchback
fabricating a VSS?
I have been thinking about how I would like to be able to make a modification and see, instantly, how much of a difference it makes. Having a non-OBDII vehicle, ScanguageII is out. MPGuino seems like a viable option, with one exception. I don't have a VSS.
My 1986 model is the first to offer TBI, and its electronic control may have more sensors than it knows what to do with, but it is still fairly basic. It has a cable-driven speedometer.
After a bit of digging, it would seem that the biggest problem with installing an MPGuino is finding the VSS wire. Well, my problem would be completely making a VSS.
How would I go about getting a VSS from another car and hooking it up? It could be a possibility to put a contact on the magnet housing behind the speedometer, but that would connect it to ground, not 12V. who knows, I may take the darned thing apart and put some contacts in there from a distributor
Does anyone have experience making this kind of situation work?
Old 05-19-2010, 07:55 PM   #2 (permalink)
Porno Music Producer
zhillz's Avatar
lolwut - '98 Honda Civic EX
90 day: 47.5 mpg (US)
My VSS is on my tranny, are there any transmission that you can swap in that would have one already to wire up too?
Old 05-19-2010, 08:12 PM   #3 (permalink)
Do you mean that I might find a VSS on the same model transmission? If this is the case, I will look the next time I go to the pick-and-pull place. I wasn't planning on a tranny swap, if that is what you were suggesting.
Besides, I want to swap the rear axle first (seriously, to get a better ratio these gears are TALL)(or I just have a weak engine)
Old 05-19-2010, 08:56 PM   #4 (permalink)
Maybe a magnet and pickup on the front of the propeller shaft, or, if FWD on the inside of the half shaft just outside of the axle seal.
regards
Mech
Old 05-19-2010, 09:55 PM   #5 (permalink)
Old mechanic, what kind of pickup are you thinking of? I don't honestly know if a reed switch could activate that fast (I figured that my driveshaft will be spinning at about 50 rev/sec, so the switch would need to be able to handle 50HZ.
Or, could I pull one off of some other car that would switch 12v with a passing magnet?
Old 05-19-2010, 10:29 PM   #6 (permalink)
ABS sensors use a gear like wheel with a magnetic pickup. Similar thing is used for OBD 2 cylinder balance counting 105 flywheel gear teeth per engine revolution on a 1995 Nissan Sentra, for passive cylinder balance calculations while engine is running without disabling any spark plugs.
Old tech cruise controls used a simple magnet on the prop shaft that gave a single impulse signal per revolution of the shaft. Differential ratio would tell you wheel speed relative to prop shaft speed.
Not necessary on front wheel drive, since half shaft speed is same as wheel speed.
Don't think a reed switch would hold up long.
regards
Mech
Old 05-19-2010, 10:36 PM   #7 (permalink)
When you say "prop shaft" do you mean the drive shaft? I am not exactly an expert on the drivetrain. My jeep is RWD, by the way. 2WD, to boot.
Thanks for the info
Old 05-19-2010, 10:43 PM   #8 (permalink)
90 day: 51.82 mpg (US)
You could buy a $9 bicycle computer which comes with the plastic encased magnet (that you would mount to a driveshaft or axle) and the pickup & wires. There's your signal. Now you just have to possibly amplify & calibrate to the Guino.
The aftermarket cruise control kit I put in my car came with similar parts for making your own VSS if the car wasn't equipped with one.
Old 05-20-2010, 07:33 AM   #9 (permalink)
Thanks for the info
Propeller shaft=drive shaft.
Right where it comes out of the transmission.
Metro is thinking about the same thing with the bicycle speedometer.
regards
Mech
Old 05-20-2010, 04:59 PM   #10 (permalink)
How well would this work?
1990-1993 Honda Vehicle Speed Sensor
I imagine that this works with a magnet that passes by. What I am wondering is how to pick a VSS that puts out 0-12V.
How to Debounce a Geo Metro VSS Coyote X OpenGauge / MPGuino FE computer 20 08-04-2014 10:01 PM
Finding the elusive VSS anthonye81 OpenGauge / MPGuino FE computer 18 03-27-2013 10:23 AM
Wanted (Alive): Aftermarket vehicle speed sensor (VSS) tygertec OpenGauge / MPGuino FE computer 17 02-09-2011 08:34 PM
[sorry] I can't find my VSS wire [/sorry] IHateMayonnaise OpenGauge / MPGuino FE computer 6 04-30-2010 01:40 AM
MPGuino self-generating its own VSS & Inj ???? nickdigger OpenGauge / MPGuino FE computer 3 09-21-2009 11:10 PM
