Old 11-27-2017, 05:08 AM   #11 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Originally Posted by Jez77 View Post
I think others use a viscous clutch and sense coolent temp from the waterpump shaft.
This is the basic idea as far as I understand them to work. It needs to be up to a certain temp before the clutch engages. But...they're also designed to run when the engine is dead cold, so the fan will be spinning when you first start up and stop running a minute or two later as it warms up. It's a fail-safe, I believe...if the viscous part of it fails, it will get stuck ON.
Don't quote me on it. Just what I picked up in the brief time I drove a truck, years ago.
Old 11-27-2017, 10:52 AM   #12 (permalink)
The fluid in the clutch will drag more when it's cold.
They are actually designed to spin 25% to 30% of crank speed when "off" with the engine bay at operating temperature. When they are cold they probably spin close to 100% of crank speed till the fluid starts to warm up.
Then nearly crank speed when "on".
They temperature of the air behind the radiator tells it when it needs to be on or off.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
redpoint5 (11-27-2017), Xist (11-27-2017)
Old 11-27-2017, 11:14 AM   #13 (permalink)
90 day: 28.24 mpg (US)
Lafawnda - '01 Honda CBR600 F4i
Big Yeller - '98 Dodge Ram 2500 base
Prius Plug-in - '12 Toyota Prius Plug-in
90 day: 57.64 mpg (US)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 24.55 mpg (US)
I'd go electric if one can be had for under $100. Then I'd need to figure out how to trigger the fan based on engine coolant temp.
Old 11-27-2017, 10:54 PM   #14 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Junkyard parts should end up a lot less than $100. You'd need a temp switch in the cooling system and a relay to power the fan.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
