Old 10-15-2008, 12:19 AM   #1 (permalink)
Nerdcycle - '81 Honda CM400E
Motorcycle
90 day: 61.16 mpg (US)
Trouble - '06 Kawasaki Ninja
90 day: 74.69 mpg (US)
Edna - '13 Nissan LEAF SV
Last 3: 126.4 mpg (US)
Tank - '20 Ford Expedition Limited
Last 3: 17.4 mpg (US)
Two fans
I was sizing up some grill blocks on the Frontier and noticed there's a second fan on the front of the AC radiator. I realize now that this probably standard issue, but I was wondering how much air it would shove through the main coolant radiator. I know I could get by without the belt driven fan in the winter, but would I be able to wire this fan to a manual switch and run all year on just it? Obviously it wouldn't be able to cope with an engine idling for several minutes while stopped at stop lights repeatedly, but moderate pulse and glide should significantly reduce the sub 25mph operation where a fan is required anyway. Am I missing something? Should I not count on this fan for anything other than AC?
Old 10-15-2008, 01:04 AM   #2 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Let me get this straight....
You block off the radiator to restrict flow through it and then you want to expend energy to restore the flow?
Old 10-15-2008, 01:19 AM   #3 (permalink)
Motorcycle
I know it sounds crazy, but it's only in case the engine starts to overheat. Even if the fan is moving 150-160 degree F air over the 220 degree F+ radiator it should help. I only want it in the rare occasion that I have to run the engine at slow speeds when it's already warmed.
Old 10-15-2008, 01:26 AM   #4 (permalink)
Red
Red's Avatar
How big is it? And how much air does it move? Unbolt your mechanical fan, and just idle it in your driveway and see how well it does. Then run with it if it works out
AC cooling off the engine?? Xringer Aerodynamics 16 08-21-2008 06:12 PM
Any Baseball Fans? RH77 The Lounge 16 04-17-2008 12:29 AM
For fans of the college world series BrianAbington The Lounge 0 02-27-2008 06:09 PM
