Old 11-08-2010, 09:15 PM   #1 (permalink)
2000 Honda Insight 5 speed man trans: Pulse, forced stop, glide, repeat questions
2000 Honda Insight 5 speed manuel transmission: Pulse, clutch in, shift netural, forced stop, clutch out, glide, clutch in, grear in, bump-start, repeat -- will this cause any problems? what the best mod to do this keyless? Will the headlights turn off when you key force stop?
I am planning on getting a 2000 Honda Insight tomorrow and I want to mod and hypermile it up to 100mpg.
Old 11-09-2010, 04:07 PM   #2 (permalink)
I use the keystart, not bumpstart, less wear & tear (IMO). The lights remain on.
Old 11-09-2010, 04:14 PM   #3 (permalink)
@silverinsight2
What are the best mods out there for FAS? Is there a mod to turn your Insight headlights off for daytime use?
Old 11-09-2010, 06:58 PM   #4 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
I just hit the kill switch to kill, and tap throttle to re-start. Keeps the all-important mpg meter running, not to mention the airbags.
See this thread, which summarizes my thoughts on P&G above 40mph:
http://ecomodder.com/forum/showthrea...p-g-13206.html
For FAS, you should build yourself one of these: http://99mpg.com/mima/thefassystem/
Old 11-10-2010, 07:09 AM   #5 (permalink)
@silverinsight2
Here is a detailed installation guide for the same FAS device.
An Insight FAS switch install - CleanMPG Forums
I don't have DRL, so I just use the headlight switch. Try pulling up the parking brake one notch, if the DRL's go out, mod that switch.
There is a Honda recall on the high-low beam switch. FYI.
Honda Insight Repair and Upgrade Blog by Mike
Old 11-11-2010, 05:09 AM   #6 (permalink)
discovery's Avatar
I think that FAS is a cool mode for insight insted dubble clutch, ect.
Honda Insight Parts For Sale
http://imageshack.us/g/1/10087943/
http://imageshack.us/g/1/10087939/
Bought Accord 88 LX'i on ebay.com for $380
Check out our Honda build
http://www.3geez.com/forum/showthread.php?t=67592
Also check out the Scooter we bought for $300- 92MPG
http://scootdawg.proboards.com/index...y&thread=32692
Reviving a 2000 Honda Insight "beater" Red Hybrids 215 08-10-2017 07:35 PM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
Project: Zombie Insight (2000 Honda) RobertSmalls Hybrids 191 03-03-2012 06:35 PM
2000 Honda Insight Questions wyatt Hybrids 8 12-14-2009 12:34 PM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
