Old 04-25-2012, 09:48 AM   #1 (permalink)
BA Bomb - '10 Kia Forte Ex
90 day: 29.68 mpg (US)
Fiat 500 Twin Air 69mpg??
Have caught wind of a new version of the Fiat 500. Anyone know anymore about this car and the supposed 69 mpg (imp) that it gets? Any chance it sells in North America?
***UPDATE****
Apologies, I repeated a search and found some information.
Last edited by Woodeden; 04-25-2012 at 09:56 AM.. Reason: Did search and came up with requested info.
Old 04-25-2012, 10:49 AM   #2 (permalink)
The fuel economy test in europe and the US are very different. It usually over states the EPA numbers by 25-30% depending on the car.
69mpg imp = 57mpg US or ~42mpg in the EPA test cycle. Still impressed? I'm not.
The Following User Says Thank You to tjts1 For This Useful Post:
Woodeden (04-25-2012)
Old 04-25-2012, 05:10 PM   #3 (permalink)
is mpg.....mpg....is mpg??
Thanks for the insight. Although based in Canada, I absolutely use the EPA numbers as a reference and I wish the Canadian agency ( Natural Resources ) would start using a more realistic rating. I saw the 69 mpg and thought this might be worthwhile. I continue the research. Thanks again.
Old 04-26-2012, 01:31 PM   #4 (permalink)
...beats walking...
...there are gallons US, gallons Imperial and Liters, and there are miles and meters.
...hence, the many differing FE numbers.
Old 04-26-2012, 02:48 PM   #5 (permalink)
I think the 500 with the Twin Air can be ecodriven to far exceed the EPA rating; like any car. A high efficiency 875cc twin would be a wonderful place to start -- it sounds bad ass, too!
Old 04-26-2012, 04:13 PM   #6 (permalink)
Real world fuel economy is pathetic even if you're trying to drive it economically. 37mpg US to be exact. Not worth the sacrifice.
Old 04-26-2012, 05:03 PM   #7 (permalink)
Panzerwagon - '02 Skoda Fabia
90 day: 53.88 mpg (US)
^ What he said.
The Fiat 500 was designed to beat the system, and it did. It's also fun to drive. But it's certainly not the most economical thing out there.
Old 11-14-2013, 07:40 AM   #8 (permalink)
I have a Fiat Punto with the Twinair engine.
It's larger and heavier than the Fiat 500 and I get 49 mpg on my commute to work (10 miles including cold start).
Old 11-14-2013, 12:14 PM   #9 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Welcome to ecomodder !
49 mpg or 4.8L/100km sound like a good start, given the use of the car
Using the
100+ Hypermiling / ecodriving tips & tactics for better mpg - EcoModder.com
and
65+ Vehicle modifications for better fuel economy - EcoModder.com
you'll be able to better that quite a bit
Last edited by euromodder; 11-15-2013 at 06:08 PM.. Reason: Of course it's not a diesel ...
Old 11-14-2013, 05:31 PM   #10 (permalink)
Thanks!
Yes 4.8 l/100 km, but I'm not sure why you mention diesel, as it does have a gasoline engine (and I'm planning on converting it, such that I can run it on LPG too).
My commute consists of highway mostly (speedlimit is 100 km/h).
(Still crossing a few traffic lights and rotarys though).
