Old 03-09-2011, 07:06 PM   #1 (permalink)
darcane's Avatar
Ten Gas Saving Tips and Exceptions for Real People - Jalopnik
ten-gas+saving-eco+tips-everyone-should-know-and-ten-exceptions-to-the-rules-for-real-people
Nothing enlightening and I think the exceptions are mostly for humor value. But, at least it's something.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 03-09-2011, 07:42 PM   #2 (permalink)
Glad Ford put something out... wonder where it's hiding?
Old 03-10-2011, 05:04 AM   #3 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
For us - yes, but I can imagine some people actually think of those exceptions as excuses. Here are some examples:
3. No idling
Exception: You car doesn't have one of these magical "today's engines." If you don't warm it up, you leave a cloud of blue smoke in front of your house so thick that the vegetation in your front lawn dies off.
How does one define "today's engine"? One might think anything built in the last 2-5 years, while there are probably 15 y.o. engines which shouldn't be idled. "Today's engine" means "brand new and extra expensive" for some.
4. Check your tires
Exception: You're drag racing your muscle car, so you take some pressure out of the rears. Perhaps you're rock-crawling or sand dune-climbing in your Jeep, so you need to let pressure out of all fours.
I got my EsYouVee 'cause it's made to go off-road. Yeah, I never been off the pavement in the 18 years I own it, but one day I might need to. So I'll keep my pressure extra low, just in case.
10. Consolidate trips
Exception: Your hectic schedule is constantly varying from day to day. You have no idea where you'll be or what you'll be doing 5 hours from now.
How was I to know earlier that I'll need 12 beers this evening, instead of the usual 10?
Old 03-10-2011, 11:29 AM   #4 (permalink)
The bit about the heater isn't all that accurate - the heater is free to use in terms of fuel. the only way it could use fuel is the extra load on the alternator to spin the blower. This is pretty minimal and the heater and blower are independent. My truck flows a lot of air with the blower off anyway (cowl pressure ftw!). The AC of course adds quite a lot of additional load, but the motor is making heat anyway, the only question is whether you want to dissipate it all though the radiator or though the radiator and heater core
Old 03-10-2011, 11:56 AM   #5 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
You're generally right about the heater. A couple exceptions:
- My car often doesn't reach full operating temperature before I arrive, so using the heater will keep it in gas-thirsty warmup mode longer. Once it's warm, the heater is nearly free.
- If the heater is also running AC for the dehumidifying effect. Many modern cars do this "automagically".
Old 03-10-2011, 12:06 PM   #6 (permalink)
Very true on the second point, on the first I'm not sure - the t-stat stays closed till its warmed up regardless of whether you have the heater on. Only diff is flow though the heater core vs/rad. Having the heater on shouldn't alter warm up time much if any.
If you have an automagic car you could put a toggle switch in the dash to disable the AC compressor clutch easily enough
One area where the heater will improve mpg is if you are in the city and the motor is hot enough that the cooling fan or fan-clutch is doing its thing
Old 03-10-2011, 12:14 PM   #7 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
Is it just me or do they put a retarded spin on everything they cover?
Old 03-10-2011, 12:27 PM   #8 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
I see a lot of articles like this popping up lately, I guess gas is getting expensive again?
I haven't noticed.
I try to help people sometimes, but have pretty much learned that unless they ask they're not willing to change. You should see how hard of a time I have convincing people they don't get there any faster doing 55 versus 65.
Old 03-11-2011, 09:21 AM   #9 (permalink)
Hypermiler
Wagons
I've done that, when it's 100+ degrees out.
Sliding the temperature selector to Hot, even with the fan off, extends my already long warmup by miles. Maybe not all cars are like that, but mine is. I guess my heater core is a direct line that bypasses the thermostat.
