Old 11-23-2012, 02:44 AM   #1 (permalink)
Greetings from Washington, D.C.
I've been a long time lurker but I figure I should start participating.
I'm currently building my Civic project car with the following:
* D16Z6 block overbored +1mm (from a 1992-1995 Civic EX/Si for non-Honda folks)
* 9:1 pistons
* D15B8 8-valve head (from 1992-1995 Civic CX)
* T28 turbo, planning on running 5-7 PSI of boost
* CX/VX transmission
Feel free to give me grief. I probably deserve it
Old 11-23-2012, 09:48 AM   #2 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Well, at least you've got the idea right about going with the taller geared transmission. Adding a turbo for economy makes sense if you gear it up.
Welcome to the forum.
Old 11-23-2012, 10:22 AM   #3 (permalink)
With the low compression it'll run decent at cruising but it's going to be very slow getting up to speed = more throttle = more fuel consumption.
I'm hoping that with the turbo assist it can get up to speed more quickly and use less gas. Then it can cruise out of boost.
