Old 08-10-2014, 11:02 PM   #1 (permalink)
50 MPG ACHIEVED!!! 94 Civic VX
The old girl did it folks. Starting with a tank full at 10.002 gallons of gas and ending at 503.5 miles on the trip odometer, I finally reached the ever coveted 50 MPG on my stock 94 Honda Civic VX. (i.e. 50.33 for those doing the math)
It took a lot of driving on the freeway at an average of 55 MPH, along with quite a few hypermiling techniques and some angry faces on the road; but my goal was finally achieved.
In terms of what it took, I'm happy to say that I spent more of my time than money to correct everything mechanically that former owner had done (eg. A cracked exhaust manifold from a Civic EX, Autolite spark plugs, wires etc.) rather than taking it to a mechanic. By my own admission, it took me the better part of this summer to fix these problems; but thanks to the advise and generosity of the forum, all became possible.
Old 08-10-2014, 11:25 PM   #2 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
I'm going through what you just did (repairs that the previous owner refused to fix) and I'm hoping that when I'm done, I'll be able to get 50+mpg myself. Anyway, good job man! I'm glad you were able to finally achieve your goal!
Old 08-10-2014, 11:38 PM   #3 (permalink)
From what I could tell, the former owner didn't know anything about working on cars, given the many receipts that he'd left behind for me; but with said, he kept good records, and knew well enough when to take it in for everything.
Thankfully, I was happy to talk him down $400, given the surprise he had in store with the exhaust manifold. That required a stock set-up with both new & used parts. For those reading this, I've learned that an exhaust manifold for a 92-95 Civic CX and VX are the exact same part. The catalytic converter however; requires you to buy a new OEM part. Plus, the L1H1 5-wire Wideband Oxygen Sensor can be found on Ebay for less than $200.00.
Old 08-10-2014, 11:40 PM   #4 (permalink)
iveyjh's Avatar
none - '98 Honda Civic HX
none - '00 Chevy (Geo) Metro base
none - '00 Saturn SL1 base
I'm probably wrong, but the way I read this is you filled up first with 10.002 gallons but do not mention a fill up after the 503.5 miles. Did you fill up at the 503.5 miles? If so how many gallons? Maybe I'm misunderstanding, if so, no bad intent.
Old 08-10-2014, 11:51 PM   #5 (permalink)
Oh sorry. To be clear, I refilled the tank to 10 gallons even tonight at 503.5 miles. My last fill-up when I'd started was 10.002 gallons of gas. I might have done it backwards; but at any rate, the result still came out to be about the same.
Old 08-11-2014, 12:07 AM   #6 (permalink)
Each angry face increases your mileage by 0.1 MPG, right?
Old 08-11-2014, 12:10 AM   #7 (permalink)
Furry Furfag
If that was the case, I would always be 15mpg over what I'm actually getting haha.
