Old 09-20-2017, 10:22 AM   #1 (permalink)
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
Florida Hurricane debris to energy
https://www.bloomberg.com/news/artic...a-s-power-grid
Old 09-20-2017, 10:52 AM   #2 (permalink)
Makes sense to use certain residues as an alternate fuel for power generation.
Old 09-20-2017, 11:41 AM   #3 (permalink)
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
There is no reason why technologies aren't put to practice where all waste is turned back into energy of some kind.
It is completely insane to bury waste in the earth that doesn't decompose in a reasonable amount of time.
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
Old 09-20-2017, 11:45 AM   #4 (permalink)
Even more insane is when the methane generated by the decomposition of organic waste is not recovered for energy purposes, like it still happens at some landfills and most wastewater treatment plants.
Old 09-20-2017, 12:21 PM   #5 (permalink)
sendler's Avatar
We need to get very good at this and figure out how to reduce any of the draw backs to trash buring power plants. Which is mainly just a matter of making sure we recyle all of the plastic, batteries, and lightbulbs out of the stream.
All of this potential energy is already riding around on a truck. Might as well get good at making a little electricity out of it.
The ash is then perfectly suitable as "cap" for traditional landfill use to eliminate having to buy the other types.
Old 09-20-2017, 11:11 PM   #6 (permalink)
It might be quite labor-intensive to make sure all the waste supplied is safe to use as a fuel. But anyway, it's often pointed out that painted wood should not be burned due to the chemicals found in paints, so it would also require some filtration of the smoke to reduce the amount of contaminants eventually released into the atmosphere.
I remember when I went to a coal-fired power plant, and there was at least one cement industry nearby that used most of the heavy ash.
