Old 09-10-2011, 04:19 PM   #1 (permalink)
Whitey - '10 Ford Ranger XL
Pickups
90 day: 33.74 mpg (US)
Hershey - '13 Nissan Altima SL
90 day: 28.68 mpg (US)
Midas - '10 Toyota Prius two
FNG with a 2010 Ford Ranger 2WD with a 2.3L I4 engine
I want to see if I can double the factory fuel economy. I started a facebook page, if you care the name for that is MPGranger, as well. Right now all I have done to the truck is a drop-in K&N air filter and a magnaflow muffler. Last fill up I was sitting at 27.2 MPG. My drive to work is 10 miles of 65mph highway and 6 miles of construction hell. I am going to have the oil changed soon and I plan to put in the lightest weight synthetic oil.
Big question, does anybody suggest using fuel additives to increase MPG? Do they actually clean your engine as they suggest? Are they cost effective?
Old 09-10-2011, 10:39 PM   #2 (permalink)
Intermediate EcoDriver
Mustang Dave's Avatar
Trigger - '07 Ford Mustang V6 Premium Coupe
Team Mustang
Sports Cars
90 day: 32.76 mpg (US)
Big Red (retired) - '89 Ford F-250 4wd Custom
90 day: 18.13 mpg (US)
Big Red II - '13 Ford F-150 FX4
Pickups
90 day: 19.61 mpg (US)
Welcome aboard.
In my experience, K&N air filters pass too much dirt through the engine (I live on a dirt road), and make no difference in fuel economy.
And also in my experience, mufflers make no noticeable difference in fuel economy.
Same goes for fuel additives.
The things that make the biggest difference in fuel economy are adjustments to the commuting route, and adjustments to "the nut behind the steering wheel".
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy View Post
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh View Post
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
Old 09-10-2011, 10:47 PM   #3 (permalink)
I'd like to lose weight, grow hair, and double my income too, but without a plan it is even less likely to happen.
Old 09-11-2011, 06:16 PM   #4 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Welcome to ecomodder.
Starting with 22 city/27 highway MPG, it ain't going to be easy.
You won't get there by buying stuff to put in the tank.
It's going to be hard work.
To give you an idea, cleampg.com put some of the best hypermilers in an F150 Ecoboost and let them have a go with it.
They didn't double the factory fuel economy numbers - 17 city/23 highway MPG - though they did get 32.3 despite 2000 lbs of load (gear + pax).
It's possible though.
DieselDave did double the numbers for his Ram 2500.
http://ecomodder.com/forum/showthrea...ank-17880.html
Have a look at his posts to see how he's doing it.
They're unlikely to help much though.
If you do short trips, you could get an oil more tailored to that sort of use.
Get off the highway.
DieselDave :
most of the time I'm at 45 mph or lower.
That works, especially for cold starts.
Get a "fuel efficiency" oil that meets the required specs for the Ranger.
Lighter transmission oil also helps a bit.
Good fuel is good as-is.
You can try the premium fuels and see if they work for your vehicle - but they're just going to push you a few % further (at a cost).
See the hypermiling tips and start practicing as many as possible :
100+ Hypermiling / ecodriving tips & tactics for better mpg - EcoModder.com
A couple eco-mods wouldn't go amiss either:
65+ Vehicle modifications for better fuel economy - EcoModder.com
Increased tyre pressure; an aero bed cover ; grille-block; air dam; belly pan seem like a good start.
I don't want to discourage you, but 50mpg already takes a bit of work on a passenger car ...
Old 09-20-2011, 07:13 PM   #5 (permalink)
Pickups
I've really seen an increase in distance per tank, I have 1/4 left and already broke my record of 400 miles.
On another note, has anyone heard of Top Tier Gasolines? They claim their additives are better than what the government makes them put in. The most notably brand was Chevron, which is always pricier than average gas. Does anyone know if there's anything to this?
