Old 11-10-2011, 01:03 PM   #1 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Frequency divider for VSS
I have a question for the electronics experts. My Honda's alternator has two charging modes. A high-output mode of 14.5 volts and a low-output mode of 12.5 volts for better MPG. The ECU selects one of these two modes based on a few different inputs. One of these is vehicle speed. The alternator is always in high-output mode over 40 MPH. My speedometer and odometer are cable-driven, the VSS in the speedometer is only for the ECU. So what I want to do is cut the frequency of the VSS in half to get the low-output mode at speeds up to 80 MPH. Even 60 MPH would be fine. I know this can be done with a 555 timer in monostable mode as shown in this link. What I don't know are the values for the resistors and capacitors in the circuit. I guess the VSS signal is 8200 counts per mile, based on the MPGuino Wiki page. It's a reed switch that grounds itself four times per cable revolution. I just want to space those ground pulses apart a little more. Any advice on what component values to start with would be great.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 11-10-2011, 02:03 PM   #2 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
I'm not sure you're going to want to use a monostable 555 as a frequency divider. It is true that you can build a sort of frequency divider out of a 555, but it's only good at actual frequency division for a narrow range of frequencies. You feed it a variable frequency signal, like out of a VSS, and you're going to get wacky results.
Suppose you make a 555 circuit to divide by 2 at some frequency F. Now, at input frequencies below F/2, the circuit will not divide at all, but will pass that frequency F. Between input frequencies of F/2 and F, the circuit will divide, but it will not divide reliably by 2 until the input frequency comes close to the design frequency F. At input frequencies above F, the circuit will tend to always pass an output frequency of F/2 regardless of the input frequency.
Now, if your instrument cluster does not depend on an accurate VSS signal, then the 555 circuit would be good enough. In that case, I'd recommend a starting point of R1 = 3.6K ohms, and C1 = 2.2 uF. That should get you a designed F such that you'll see division by 2 at about 55 MPH. That's assuming, of course, that your VSS does spit out 8200 pulses per mile.
Last edited by t vago; 11-10-2011 at 05:01 PM.. Reason: corrected values for R1 and C1
The Following User Says Thank You to t vago For This Useful Post:
Gasoline Fumes (11-10-2011)
Old 11-10-2011, 02:39 PM   #3 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
Thanks, I'll give that a try! As long as the ECU can tell whether the car is moving or not, I think it will be OK.
Is there any particular 555 part number I should be looking for? Being inside a car in NY, it wlll be subjected to temps from about 0°F to 120°F.
My other idea was to manually engage the low-output mode of the alternator. I just have to figure out what signal the ECU sends to the alternator.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 11-10-2011, 02:49 PM   #4 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
Now that I read that again, that's what I initially wanted. I just assumed dididing by 2 would be easier. I just really want to trick the ECU into thinking I never exceed 65 km/h or 40.3 MPH. Does that change your recommended values?
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 11-10-2011, 03:33 PM   #5 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
I wonder how it behaves if you simply disconnect the cable.
Old 11-10-2011, 05:03 PM   #6 (permalink)
MPGuino Supporter
t vago's Avatar
Yes, it does. R1 become 3.3K ohm, and C1 becomes 3.3uf. Your car's engine computer would never see any speeds above about 40.31 MPH.
As far as simply disconnecting the VSS wire, I imagine it would throw a code.
Old 11-10-2011, 06:50 PM   #7 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
Yep, check engine light will come on during deceleration.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 11-11-2011, 05:59 AM   #8 (permalink)
Eco-ventor
jakobnev's Avatar
House of Tudor
Team Mazda
Plug-in Hybrids
Frequency Division using Flip-flops
If the ECU wants pulses of constant length, then a circuit with a 555 might be useful as a last step.
It's always a pity when the ultra simple solution doesn't work.
